Why is my gas mileage sooo bad.......?.....
Old Sep 27, 2003 | 01:23 PM
TypeRuz's Avatar
Default Why is my gas mileage sooo bad.......?.....
From my last post on gas mileage it is obvious to me that i'm getting bad gas mileage. i get maybe 220 miles per 11 gallons, mostly highway driving. also, i've determined that my car is definetely running slow too. my brother's 2000 prelude beats me by 2 cars by 80 mph, even if we switch drivers (equal driving skill b/w us, both stock cars). someone told me the car feels like a GS-R in terms of power.
i bought the car used a few months ago on the spur of the moment and since i never drove a stock type r, i couldn't tell at that time it was running slow.
i'm killing myself trying to figure out what's wrong. i already replaced: PCV, spark plugs, fuel filter, air filter, and had the valves adjusted. the stupid dealer said it's my clutch, but it's not slipping at all, and other people confirmed its working fine, even a performance shop that sells clutches.
so, what could be causing me to have bad gas mileage and run slow??? (my next thought was fuel pump....?)
any ideas are appreciated.
Thanks!!!
Old Sep 27, 2003 | 01:28 PM
hungsteR's Avatar
Default Re: Why is my gas mileage sooo bad.......?..... (typeruz)
What do you mean you bought it on the psur of the moment? Did you not get the car checked out before you bought it?
If the car is under warranty take it in. Or, you can have one of the FL We-Todds check out your car
Old Sep 27, 2003 | 02:01 PM
Bbasso's Avatar
Get it on a dyno and see whats going on with youur power output and what your a/f is.
A good tuner will be able to see more then you think.
Old Sep 27, 2003 | 02:14 PM
IGGY's Avatar
Default Re: Why is my gas mileage sooo bad.......?..... (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Get it on a dyno and see whats going on with youur power output and what your a/f is.
A good tuner will be able to see more then you think.</TD></TR></TABLE>
Good point. Also consider taking it to get fully inspected by someone who knows what they are doing.
Old Sep 27, 2003 | 02:39 PM
reverie's Avatar
Your best bet. Good luck.
Old Sep 27, 2003 | 06:22 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeruz &raquo;</TD></TR><TR><TD CLASS="quote">From my last post on gas mileage it is obvious to me that i'm getting bad gas mileage. i get maybe 220 miles per 11 gallons, mostly highway driving. also, i've determined that my car is definetely running slow too. my brother's 2000 prelude beats me by 2 cars by 80 mph, even if we switch drivers (equal driving skill b/w us, both stock cars). someone told me the car feels like a GS-R in terms of power.
Thanks!!!</TD></TR></TABLE>
how many miles do you have on the car? is your car stock?
Old Sep 27, 2003 | 08:34 PM
Black R's Avatar
25 Year Member
.....I have the same ****** problem.
Any CEL's?
I'm just gonna rebuild the POS.
Old Sep 27, 2003 | 08:59 PM
xpnsivCTR's Avatar
Default Re: Why is my gas mileage sooo bad.......?..... (Black R)
use sunoco 94 it works 4 me i get 350 miles from a full tank..
Old Sep 28, 2003 | 12:19 AM
TypeR_853's Avatar
i agree...that's good advice
you should really check if you still have any type of warranty left on your ITR
btw, do you know if the previous owner did any modifications before you bought it...
Old Sep 28, 2003 | 05:41 AM
twuelfing's Avatar
check the tire pressure.
seems obvious but it will dramatically reduce MPG. If you already did this then disreguard this as an idiodic comment.
Old Sep 28, 2003 | 07:19 AM
rizen's Avatar
I get around 220-250 per gallon as well man. I'm also always on the highway. Maybe it's this hot FL weather =p
Old Sep 28, 2003 | 09:55 AM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: (r1zen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1zen &raquo;</TD></TR><TR><TD CLASS="quote">I get around 220-250 per gallon as well man. I'm also always on the highway. Maybe it's this hot FL weather =p</TD></TR></TABLE>
220-250 per gallon!!! ****!!!
Old Sep 28, 2003 | 10:05 AM
MikeD's Avatar
New User
Have you had the compression checked?
Old Sep 28, 2003 | 10:52 AM
STOLEN - ITR 98-0652's Avatar
I get that kind of mileage, too...
It doesn't bother me... much. Of course, I'm on it all the fricking time... and I'll putt around town at 5000rpm rather than upshift.
Old Sep 28, 2003 | 07:53 PM
rizen's Avatar
Default Re: (arizsun21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arizsun21 &raquo;</TD></TR><TR><TD CLASS="quote">
220-250 per gallon!!! ****!!! </TD></TR></TABLE>
heh heh...
Old Sep 28, 2003 | 08:18 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeruz &raquo;</TD></TR><TR><TD CLASS="quote"> my brother's 2000 prelude beats me by 2 cars by 80 mph, even if we switch drivers (equal driving skill b/w us, both stock cars).
street racing w/o nos explains it.
Old Sep 28, 2003 | 10:35 PM
ArizSun21's Avatar
Default Re: (r1zen)
heh heh...</TD></TR></TABLE>
Sorry man had to do it... no hard feelings
Old Sep 28, 2003 | 11:28 PM
rodimus's Avatar
you have any buds that work on cars?
you burn any oil?
maybe you should have someone check to see if a previous owner
swapped the cams out for gsr cams or something...
other than that compression tests would be cool..
Old Sep 29, 2003 | 02:25 PM
rizen's Avatar
Default Re: Why is my gas mileage sooo bad.......?..... (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">
street racing w/o nos explains it.</TD></TR></TABLE>
Typical moronic comment
Old Sep 29, 2003 | 02:37 PM
sa21199's Avatar
Default Re: Why is my gas mileage sooo bad.......?..... (r1zen)
Burning oil? Compression test might reveal something. Dyno is a good idea
VTECwalka
20
Jan 28, 2013 07:06 AM
VTECwalka
Jan 21, 2013 02:19 PM
Fat Chick Magnet
Oct 6, 2008 10:28 PM
b18LS
Aug 17, 2007 02:10 PM
PIBBSTER
Oct 9, 2005 08:27 PM
