dammit have a ? need a fast awnser
Old Sep 27, 2003 | 06:45 AM
slowpokesi's Avatar
Default dammit have a ? need a fast awnser
i need some info fast,
are all b series oil pans the same?
supposedly the fucknuts who changed my oil last, stripped the pan and bolt, so i need a new pan, asap.
so do i have to try and source a jdm 1st gen b16a oil pan or will one of of a del sol vtec, 99 si vtec or maybe even a gsr work?
please reply fast.
Old Sep 27, 2003 | 06:49 AM
Limited S.L.I.P.'s Avatar
Default Re: dammit have a ? need a fast awnser (slowpokesi)
del sol DOHC VTEC def works. When my friend bought his motor they told him to you that pan (he needed one also)
**EDIT** SORRY- he bought a B16a2.. i'm not sure if they are the same.. sorry-
Old Sep 27, 2003 | 09:07 AM
RCautoworks's Avatar
Default Re: dammit have a ? need a fast awnser (Limited S.L.I.P.)
Here is the bolt pattern of a gsr oil pan, it might help a little to compare to your 1 gen b16 oil pan.
http://www.we-todd-did-racing....DE%3D
I'll try looking for the bolt pattern on a del sol b16 oil pan and a 00 si oil pan. I'm almost 100% sure you could use the del sol and the 00 si oil pans on the 1 gen b16.
Old Sep 28, 2003 | 06:46 AM
slowpokesi's Avatar
i still need help with this.
Old Sep 28, 2003 | 06:51 AM
.ShawnD.'s Avatar
yes they are the same at least the 99 si one worked
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
I believe that all b series oil pans are the same. Im not sure but im pretty positive. I had a gsr oil pan on my b18a soim pretty sure it would work.
Sean
Old Sep 28, 2003 | 09:51 AM
turboZChatch's Avatar
The ones off of the del sol's with a b16 in them will deff work I am not gonna say the others do because I have no personal experiance with them
Old Sep 28, 2003 | 10:17 PM
4inspeed's Avatar
Default Re: dammit have a ? need a fast awnser (turboZChatch)
well lets try this.......
wich of these parts from b series vtec motors dont interchange.
cams.
transmissions.
head.
intake manifold(with exeption of a gsr)
header, or exhaust manifold (same exeption)
valve cover
alot more but im tired
now this is one reason i like honda so much. most of there b series parts are interchangable. now im not posotive about the pan, but my guess is they would be. now i would have to say if honda left all the other things the same, and changed the design/bolt pattern of the damn oil pan just to through people off then that would be dumb, so my guess is yes (dont take my advise im prolly wrong).
ok now that my drunken rambling is over, im gonna go to bed now.
Old Sep 29, 2003 | 12:04 AM
civickiller's Avatar
Default Re: dammit have a ? need a fast awnser (4inspeed)
my obd0 ls oil pan is the same as a 1st gen b16s one
Old Sep 29, 2003 | 05:07 AM
CRneXt's Avatar
If you are going to remove it anyway...
You can take it to a reputable WELDING shop, and have the old plug welded up, and a new plug installed into a short pipe nipple. This can also be a good time to have an oil return line installed for future dry sump, or turbo... Even Both!! have them capped until ready for use, if you do this...
That old pan is not a total loss...
Scott
Old Sep 29, 2003 | 06:08 AM
ricodemus's Avatar
Default Re: dammit have a ? need a fast awnser (CRneXt)
ls/b16 oil pans are the same.
Bryedawg
Aug 30, 2018 08:26 AM
Del Sol Man
13
Dec 20, 2004 08:58 AM
playAho
Sep 7, 2004 11:59 AM
crxbust
Apr 4, 2004 06:53 PM
CBR
May 7, 2002 07:59 PM
