My Del Sol fell off the jack & dented oil pan, what is needed to repair?
Old 12-20-2004, 07:39 AM
Del Sol Man's Avatar
Default My Del Sol fell off the jack & dented oil pan, what is needed to repair?
I did a dumb thing and my Del Sol fell off a jack and landed on a 4x4, denting the oil pan pretty bad. I think I should replace the pan so it doesn’t distort and leak but I don’t know if I would have crushed the pick up. The dent is in the front and the back is intact. Where is the pick up? Help?
Steve
Old 12-20-2004, 07:42 AM
TheIntegraGuy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Steve</TD></TR></TABLE>
What pick up are you talking about?
Just get a new oil pan.
Old 12-20-2004, 07:43 AM
smithenhiven's Avatar
Default Re: My Del Sol fell off the jack & dented oil pan, what is needed to repair? (Del Sol Man)
Pull the pan, and see what's going on, then replace any damaged parts
Old 12-20-2004, 07:45 AM
PLAN:B's Avatar
Default Re: My Del Sol fell off the jack & dented oil pan, what is needed to repair? (smithenhiven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smithenhiven &raquo;</TD></TR><TR><TD CLASS="quote">Pull the pan, and see what's going on, then replace any damaged parts</TD></TR></TABLE>
Thank god you weren't under there bro Goodluck w/ the repair
Old 12-20-2004, 08:10 AM
Del Sol SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeterkm02 &raquo;</TD></TR><TR><TD CLASS="quote">4x4 would be a piece of wood.. ever hear of a 2x4?
anyways. pull the oil pan off and make sure the oil pickup is still in tact. if its crushed replace it. you dont want to starve your motor of oil</TD></TR></TABLE>
Ah I get it now...
Modified by DelSolSiR at 9:32 AM 12/20/2004
Old 12-20-2004, 08:13 AM
Cray91's Avatar
Just pull the pan off and see if you bent/broke the oil pick-up. It isn't that hard, just have it up there better than when you smashed it.
Old 12-20-2004, 08:14 AM
khmboostedeh2's Avatar
Default Re: My Del Sol fell off the jack & dented oil pan, what is needed to repair? (DelSolSiR)
Old 12-20-2004, 08:31 AM
Default Re: My Del Sol fell off the jack & dented oil pan, what is needed to repair? (Jeterkm02)
The Del Sol fell off a piece of wood (4x4x8") that was on my floor jack to give me enough height to get the 6 ton jack stands out. It is in the garage af a very idiotic mechanic, mine. I am always 100% sure there are multiple supports before I get under the car but I got a little careless when I was not under there myself.
Before I pull the pan (in zero degree weather) I was wondering if the oil pick up is in the front or back of the pan as I smashed the front only. BTW, what are the chances of pounding out the pan?
Anybody know the torque value for the pan bolts?
Steve
Old 12-20-2004, 08:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol Man &raquo;</TD></TR><TR><TD CLASS="quote">Before I pull the pan (in zero degree weather) I was wondering if the oil pick up is in the front or back of the pan as I smashed the front only.</TD></TR></TABLE>
Hope this helps...
Old 12-20-2004, 08:48 AM
Thanks for the .jpg! I can't see the oil pick up. Could it be #20 & 30?
I think the pan is going to be expensive.
Steve
Old 12-20-2004, 08:50 AM
adictionbass's Avatar
that pic doesnt show the position of the oil pick up killa. From looking at the engine, the pick up is on the right side pretty much in the middle. (at the deep part of the pan)
Old 12-20-2004, 08:55 AM
Del Sizzle's Avatar
Oil Pan Prices and part numbers ......
sohc
S Model & Si Model
93-95 11200-P08-020 $183.40
96-97 11200-P2E-000 $ 79.88
dohc
94-97 11200-P30-010 $114.49
Old 12-20-2004, 08:57 AM
VN712's Avatar
Default Re: My Del Sol fell off the jack & dented oil pan, what is needed to repair? (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">that pic doesnt show the position of the oil pick up killa. From looking at the engine, the pick up is on the right side pretty much in the middle. (at the deep part of the pan)</TD></TR></TABLE>
The pick up is in the middle, like he said. Oil pan for a d-series is pretty cheap about 30-100 bucks in the classified.
Old 12-20-2004, 08:58 AM
VN712's Avatar
Default Re: My Del Sol fell off the jack & dented oil pan, what is needed to repair? (Del Sizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sizzle &raquo;</TD></TR><TR><TD CLASS="quote">Oil Pan Prices and part numbers ......
sohc
S Model & Si Model
dohc
94-97 11200-P30-010 $114.49</TD></TR></TABLE>
USED is the way to go for a piece of metal that hold oil
Bryedawg
08-30-2018 08:26 AM
ruff93sol
04-25-2014 09:52 AM
The_Snowflake
11-09-2011 11:13 AM
Apocolipse269
09-08-2004 12:10 PM
crxbust
04-04-2004 06:53 PM
Quick Reply: My Del Sol fell off the jack & dented oil pan, what is needed to repair?
