Peak Hp with just bolt-ons on B16?
i'm currently running comptech intake, jdm 4-1 header, apex N-1, AEM fuel rail/ regulator, Exedy clutch, Skunk IM, and Skunk cam gears on the way. A V-afc will be soon then i plan on getting it tuned. it's a 00 Si. What numbers should i be expecting? i know i won't be puttin down anything drastic, i just want to know what some of you have put down? Thanks
mines a first gen. but i hit 159 w/little mods...
and I beat on that motor like no other.
Fram oil filter, and syntec 10w30 every 3k miles...
relplaced all maint. things. plugs, wires, dist cap rotor, fuel filter, etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_madman »</TD></TR><TR><TD CLASS="quote">mines a first gen. but i hit 159 w/little mods...
That was on that Nopi dyno though so I wouldn't rely on those numbers. Most are right at 150mp with all the bolt on's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik2kSi »</TD></TR><TR><TD CLASS="quote">i'm currently running comptech intake, jdm 4-1 header, apex N-1, AEM fuel rail/ regulator, Exedy clutch, Skunk IM, and Skunk cam gears on the way. A V-afc will be soon then i plan on getting it tuned. it's a 00 Si. What numbers should i be expecting? i know i won't be puttin down anything drastic, i just want to know what some of you have put down? Thanks</TD></TR></TABLE>
you should be happy if you break 150whp with bolt on b16
i put down 152whp with just i/h/e but my motor was just put toghter like 1700 miles ago and my fuel sucked run a chiped p28 and my a/f ratio was 11.8 so i lost aome power trying to get a new chip or a hondata and get back on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philafelman »</TD></TR><TR><TD CLASS="quote">man, whats the point of a dyno if its not even accurate?!? how can you tell if it is?</TD></TR></TABLE>
If you use that same dyno you can tell if the parts you put on or setting you change add power or not which is the main reason to go to a dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">
If you use that same dyno you can tell if the parts you put on or setting you change add power or not which is the main reason to go to a dyno.</TD></TR></TABLE>
yeah, but ive had my car on one dyno like 3 yrs ago, and when it goes back on, its gonna have a completely diff engine which will need lots of tuning...so i guess i dont really have a baseline to go off of.
mightyjoecivic
Nov 5, 2007 07:44 PM
so it's not like i didn't try...
