FPR suggestions/advice?
I'm running a JDM B16A with a homemade CAI and a crush bent 2.25 inch exhaust, timing set at 17 degrees, with a Holley 190lph pump. It runs about 38 psi at idle according to my B&M pressure guage, with the stock FPR. I recently added a set of 00 Si cams, so I was thinking maybe I should add some more fuel.
Quarter mile wise, I'm running 14.6-14.8 at about 94-95 mph, with a 9.43 1/8 at around 76-77mph (without new cams).
Does anyone have any reccomendations for getting an FPR and tuning it? Do you think I would see a gain from 1-2 psi of fuel pressure? I want an FPR that doesn't require hacking up the old one, so B&M is out. Any brand reccomendations, and pros/cons?
Thank you.
Thank you.
If you dont wanna hack saw your stock FPR. You should probably get an AEM. It should be a direct replacement. Also, a commandoflo.. It connects to your stock fpr without you cutting it up.
Yup they make Honda FPRs... fast imports at my track use these, but they're expensive... so you would reccomend AEM? Good quality, I assume?
