FPR problem....forgot my setting LOL
Old Jan 23, 2008 | 05:03 PM
PickleTeg's Avatar
Default FPR problem....forgot my setting LOL
Hey guys, here is the situation....I put on a fuel pressure gauge a while ago recorded the pressure and then put on my AEM FPR and adjusted it to what it was reading with the stock FPR. Well....soon after I installed a Walbro 190 L/hr pump and had the car tuned. Ok...good so far.
Well...lets go ahead 2 years............................................. ....................
I found my FPR was not sealing good so I rebuilt it. I turned my car on after the rebuild and realized I had 60 psi at idle. I did not mess with the screw and I know it was not that high before. I was wondering if there is a quick fix to this change in fuel pressure. I would just stick the stock FPR back on and record the number, but now I have -AN fittings and that is impossible. I don't wanna go back on the dyno if I don't have to............
Anyone got an idea of what fuel pressure i would have with the stock regulator and a Walbro 190. BTW...it is an LS.
Old Jan 23, 2008 | 05:25 PM
97grnrs's Avatar
Default Re: FPR problem....forgot my setting LOL (PickleTeg)
mine is 50-52 psi at idle with a 255 and stock reg.
Old Jan 24, 2008 | 02:00 AM
PickleTeg's Avatar
Default Re: FPR problem....forgot my setting LOL (97grnrs)
Thanks! Anyone else?
Old Jan 24, 2008 | 03:53 AM
non-VTEC's Avatar
40-45psi with the vacuum hose connected should be perfectly fine.
Hondero_PR
Jul 24, 2012 12:07 PM
91-lsvtecsi
Apr 24, 2012 04:46 PM
Teamdiesel
11
Nov 11, 2007 05:39 PM
spooned out
Jun 15, 2004 06:44 PM
J.R.
Mar 18, 2003 04:38 PM
