Timing belt a lil loose....... need some help if u can.....
Old Sep 26, 2003 | 07:54 AM
slooogsr's Avatar
Default Timing belt a lil loose....... need some help if u can.....
i just tried to change my cam seal and in the process i had to pull the Tbelt of and loosen the tensioner......... i couldnt seem to get the cam pulley off so due to time issues i put everything back together.......... i got everything lined up/ cuz i marked the camgear positions and belt positions with a piece of white chalk......... lined everything up and starts fine and runs fine........... but i noticed more slack in the timing belt........ ive tried messing with the tensionner to make sure its tight and i cant get any more tightness out of the belt.......... is there another adjustment i have to make?? i can almost pull the belt right back off the cam gears again......... any help would be awesome!
-Jared
Old Sep 26, 2003 | 08:47 AM
slooogsr's Avatar
Default Re: Timing belt a lil loose....... need some help if u can..... (sloorex)
anyone?? its loose on the exhaust side.......... thanx
Old Sep 26, 2003 | 10:56 AM
slooogsr's Avatar
ok a lil update......... im pretty sure its tight enough now but i took it for a drive and it idles fine and everything but in the 4k+rpm range its a dog and my intake screams wayyyy more than it used too........ any help would be awesome!! pleeeeezzz
Old Sep 29, 2003 | 09:39 PM
david90's Avatar
ur tb is on too tight!
NubR1
14
Jul 21, 2014 05:45 PM
freshCROOKS
Aug 14, 2012 06:38 PM
sdboostin111
May 13, 2010 07:11 AM
rough_draft
Mar 29, 2005 04:52 AM
AdamITR
Aug 28, 2002 07:11 PM
