How to take off the shift rod.
Old Aug 25, 2001 | 08:12 AM
gsr squirrel's Avatar
New User
Default How to take off the shift rod.
Ok I'm having some problems trying to get this thing off. I got everything off except for the part where it connects to the transaxle. I took off the little clip and now i'm stuck. The manual i'm using says to push out a spring pin with a pin push. Only thing is i don't see any spring pin. All i see is a hole at the end of the rod that wsa covered before by a clip. Can anyone help me out?
Old Aug 25, 2001 | 09:31 AM
blaze's Avatar
Default Re: How to take off the shift rod. (gsr squirrel)
that spring pin should be in there. get down there again and loot at it carefully. to get it out, get a punch or an old small socket thats the same diameter as the spring pin and hammer away. hth
Old Aug 25, 2001 | 11:10 AM
New User
Default Re: How to take off the shift rod. (blaze)
anyone have a close up of what the spring pin looks like? i see this black piece inside the hole and i've tried hammering it out but it doesn't go anywhere
Old Aug 25, 2001 | 11:43 AM
owen_the_soyboy's Avatar
oh you poor poor poor man... that took me over one hour to pound out.
yes its in there, it is a black hardened steel tube, like a piece of sheet steel that has been rolled into a tube shape... with interlocking serrated ends... these provide a grip on the ID of the shifter hole it goes thru.
what a completely unecessarily hard part to remove.
get the car jacked up as high as possible and go at it with a punch the right size, otherwise you will spreadi it out / flare it and that makes it even harder.. dont ask me how I know that
hth, and good luck...
Old Aug 28, 2001 | 10:22 AM
9KRacer's Avatar
New User
Default Re: How to take off the shift rod. (owen_the_soyboy)
The only way to get it out is with a punch. I messed up 2 screw drivers and smashed the $hit out of my hand with a hammer. I got a punch set from Sears ($31 bucks later) had a punch set, and MORE TOOLS! 20 seconds later I had the pin out. I believe its 5/32 or 7/16.. One of the two. Use a punch!
Old Aug 28, 2001 | 11:07 AM
yaksplat's Avatar
Default Re: How to take off the shift rod. (9KRacer)
i used an 8mm cap screw ($0.79)
picked the length that i wanted and it came out in a few seconds
a little penetrating lube doesn't hurt either
Old Aug 28, 2001 | 01:12 PM
miketegra's Avatar
Default Re: How to take off the shift rod. (yaksplat)
The others are correct - use some WD-40 or some other penetrating oil and let it soak in.
Lots of pounding with a BFH (big fvking hammer) and a good punch, and that pin will pop right out !
Old Aug 28, 2001 | 11:44 PM
C-speed's Avatar
Default Re: How to take off the shift rod. (miketegra)
Look here:
http://www.c-speedracing.com/howto/b18cswap/swap.html
Old Aug 29, 2001 | 05:56 AM
keithv's Avatar
Default Re: How to take off the shift rod. (G3-TEG)
To make it even easier for you (since I am bored at work)
and
Thanks to c-speedracing.com.
Old Aug 29, 2001 | 10:55 AM
gsxr for yo momma's Avatar
New User
two words....BFH....plasma cutter..
Old Aug 29, 2001 | 04:06 PM
Big Ed's Avatar
Default Re: How to take off the shift rod. (gsxr for yo momma)
That's five words.
Jon Petersen
Sep 5, 2017 01:58 PM
sanman000719
Aug 21, 2011 05:58 PM
eM1<3
Aug 8, 2009 07:20 PM
hollot1p
Jul 29, 2006 02:08 PM
BDogggUT34
Feb 11, 2005 03:46 PM
