I have never ported what is it like.
Old Sep 24, 2003 | 07:50 PM
Torridcivic's Avatar
Default I have never ported what is it like.
I have always gone with the small sealed boxes. But I have to say that I am lacking that feeling that you get in your chest at cocerts when the bass drum hits. I have 2 15's with 1200w RMS running to them with 31mm xmax, so I think the displacement is there but I was thinking that maybe porting would be the way to go. I want clean punchy bass, not loud as sloppy, I want to feel it in my chest. Right now my seat vibrates %80 and I feel %20 pure sound waves.
Old Sep 25, 2003 | 12:52 AM
vteg's Avatar
New User
Default Re: I have never ported what is it like. (Torridcivic)
If you have never heard a big sub ported, you are in for a good surprise The problem is you have 2 15's. I doubt you will be able to build a box for both that will fit in your civic(I am assuming you have a civic). What subs do you have, eclipses?
Anyway, if you decide to build one for experimentation, try a single tuned low. If your sub is 31mm xmax one way then you will need lots of port area, so put as much as you can get in it. My 15xxx box that I am building has 70 square inches or port.
Old Sep 25, 2003 | 06:04 AM
GSteg's Avatar
eclipse Ti has 31mm of xmax? 2-way right? lol
Old Sep 25, 2003 | 07:17 AM
SOUNDSFAST's Avatar
It's going to be hard to get tight punchy bass out of a ported enclosure let alone a ported 15. If you want alot of tight bass look at what the recommended small enclosure is for your subs.
Old Sep 25, 2003 | 02:29 PM
GSteg's Avatar
i've gotten "tight" punchy bass out of my e15k ported setup.
and if anyone wants tight bass out of a sealed box, you'll want a big box. smaller box are no-no if u want low-end extention and good transient response.
Old Sep 25, 2003 | 05:12 PM
Default Re: (GSteg)
Im not sure if the Xmax is 1-way or two way, but the foam surround is like 3" thick, two is truely too loud, I have never maxed them out. I am looking for the feel in my chest. maybe Eclipse makes SPL subs and I am looking for SQ subs. I have also never heard a JL sub either and I hear that they are SQ centered. If you could recomend a sub for me to hear ported which would it be.
Old Sep 25, 2003 | 05:32 PM
vteg's Avatar
New User
Default Re: I have never ported what is it like. (SOUNDSFAST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOUNDSFAST &raquo;</TD></TR><TR><TD CLASS="quote">It's going to be hard to get tight punchy bass out of a ported enclosure let alone a ported 15. If you want alot of tight bass look at what the recommended small enclosure is for your subs.</TD></TR></TABLE>
Why? What do you mean my tight and punchy? Is a larger sub less tight and punchy, or does the box make it that way?
Old Sep 25, 2003 | 05:34 PM
vteg's Avatar
New User
Default Re: (Torridcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Torridcivic &raquo;</TD></TR><TR><TD CLASS="quote"> If you could recomend a sub for me to hear ported which would it be.</TD></TR></TABLE>
RE xxx
Ported w7 is aiight also
Old Sep 25, 2003 | 06:21 PM
rodimus's Avatar
Default Re: (vteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg &raquo;</TD></TR><TR><TD CLASS="quote">
RE xxx
Ported w7 is aiight also </TD></TR></TABLE>
yah it's "aiight"
till it gets stolen from you lol...
anyways..vteg made me a KILLER ported box for my W7 that USED to be sealed.
ported i loss no SQ...didn't have to run so any bass boost ported...
and it felt/sounded like i had 2 or 3 sealed 10W7's when it was ported versus my old sealed setup.
Old Sep 25, 2003 | 09:38 PM
GSteg's Avatar
[QUOTE=Torridcivic]Im not sure if the Xmax is 1-way or two way, QUOTE]
i just confirmed it..xmax 1 way is only about 16mm.
ah..get a W7. put it in a ported box tuned low and boom..you're in heaven. lol
Old Sep 25, 2003 | 11:42 PM
vteg's Avatar
New User
Default Re: (EVOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL &raquo;</TD></TR><TR><TD CLASS="quote">
ported i loss no SQ...didn't have to run so any bass boost ported...</TD></TR></TABLE>
Down with bass boost
With ported you don't need that stuff anyway
Old Sep 26, 2003 | 01:35 PM
Default Re: (vteg)
by tight and punchy I want a sub that you feel, porting makes since, more air displacement with less volume. THat is really what I am looking for a sub that when I turn my highs up it does not overpower and block out thier sound, but I still want to be able to feel it and have it contribute to the system. W7 huh, some guy at my school said he has two W6's for sale for $400 But I think it's BS, plus I really one would want one sub, and W7 is the JL top of the line right? XXX I'll look into that.
Correct me if I am wrong but I am looking for a SQ sub, that i will port right?
Old Sep 26, 2003 | 05:49 PM
PetroGuyX's Avatar
Correct me if I am wrong but I am looking for a SQ sub, that i will port right?</TD></TR></TABLE>
correct, dub7 gets my vote
Old Sep 26, 2003 | 06:07 PM
vteg's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Torridcivic &raquo;</TD></TR><TR><TD CLASS="quote">by tight and punchy I want a sub that you feel, </TD></TR></TABLE>
Sorry that was intended for the other guy. I was just instigating a little
Too many people regurgitate what they have heard and have nothing to back up their old wives tales. Large subs are not slower and less "tight". Everyone has a different definition for tight. Some use it to refer to transient response, an advantage that sealed will always have. Some use it to refer to the midbass hump you can get from small sealed enclosures. Regardless sometimes we have to seperate the facts from the fiction.
Anyway, if you want to feel your bass tune it to the low 30's, and you will become a believer
Doodlydo
Audio / Security / Video
23
Jul 3, 2008 10:47 AM
powerdbygarrett
Nov 20, 2006 11:53 AM
TRAY
Mar 25, 2006 01:01 PM
Giga Crusher
12
Mar 23, 2005 07:10 AM
Bud
Feb 29, 2004 06:49 PM
