possible valve train problem
Old Sep 24, 2003 | 06:58 PM
Rossifumi's Avatar
Default possible valve train problem
This is the issue i installed ctr pistons into my 99 si ,also have ctr cams ,toda cam
gears,type r intake manifold, spoon head gasket . I already clayed the engine the clearance is over 35thou also the timing set at 10degrees for break in the valve adjustment was 6thou intake and 7thou exhaust just wondering if the valve adjustment needs to be tighter. The engine ticks very loud like the pistons are hitting the head loud ?
zCivic
Apr 7, 2006 05:33 PM
Tech6023
Sep 12, 2005 09:26 PM
McFly
Mar 2, 2003 08:01 PM
TheShad0w
Sep 7, 2001 12:51 PM
