S1/tranny clutch help needed please
Old Sep 24, 2003 | 09:01 AM
spaceman's Avatar
Default CRX/B16..need info on clutch/cable
i have crx/b16 and problems hehe..i got clutch cable hooked up i get in the car and the clutch pedal goes to the floor without any effort,whats up with that?problem number two is when the motor is running i cant put the shifter into any gear,but when the car is off i can,someone told me that the clutch is engaged.so can i just pull up on the clutch arm untill something happens?and what do i do about the cable?
Modified by spaceman at 6:46 PM 9/24/2003
Old Sep 24, 2003 | 09:44 AM
spaceman's Avatar
Default Re: S1/tranny clutch help needed please (spaceman)
could someone help me out?i got an acura clutch cable i had to modify it a little to make it fit.when i adjust the cable how tight should it be?the more i tighten up the slack the arm starts to go up and if i just go under the hood and pull up on the clutch arm,how hard to i need to pull it up to disengage the clutch?
Old Sep 24, 2003 | 11:21 AM
spaceman's Avatar
Default Re: CRX/B16..need info on clutch/cable (spaceman)
ok i got the clutch cable to work now,but i can only get it adjusted to where the clutch is engaging right when i start to lift off the pedal...i wanna adjust it so the clutch engages around halfway,adjust clockwise or counter?...what clutch cable fits and works the best for crx/b16?
Old Sep 24, 2003 | 11:26 AM
EL Vap133's Avatar
I used a 91 Teg clutch cable for my CRX, if that helps....
Old Sep 24, 2003 | 12:47 PM
REDBARON's Avatar
Default Re: CRX/B16..need info on clutch/cable (EVIL_Vap133)
I tightened the nut on mine to raise the release point. (Clockwise)
danno33
12
Sep 30, 2012 08:46 PM
MichealSenior
Feb 17, 2009 12:56 AM
spaceman
Sep 24, 2003 11:24 AM
DroppedTegLS
Sep 28, 2002 01:51 PM
