ATTN: Fellow boost users...help my troubles
Old Sep 23, 2003 | 07:55 PM
Mark's Avatar
*Bounty Hunter*
Default ATTN: Fellow boost users...help my troubles
Small question for you experts...Im doing standard maitenance on my stock GSR head, valve seals, and I was wondering if I should go ahead and do anythin to else to prep it for boost....
Any suggestions at all? Im looking at a streetable car thats goin to the track, somewhere around 10 psi dailydriver (on built motor later)
Old Sep 23, 2003 | 09:43 PM
Mark's Avatar
*Bounty Hunter*
Default Re: ATTN: Fellow boost users...help my troubles (94BlackCivicEX)
bump
Old Sep 23, 2003 | 09:53 PM
Flamenco-T's Avatar
Depending on your turbo setup in the future, you may want to do a research on how high you want to rev your motor to keep the boost in full efficieny, if that's the case, then just do valvesprings/retainers swaps and you will be good to go. Otherwise, just keep it stock, GS-R head flows very well as it is.
stan
Old Sep 23, 2003 | 10:44 PM
Mark's Avatar
*Bounty Hunter*
Default Re: ATTN: Fellow boost users...help my troubles (Flamenco-T)
Well a large turbo wont make as much power at higher RPMs will it? I dont want to rev higher than 8500 rpms, if that helps...Maybe I should buy some ITR springs and retainers? Would those suffice?
DutchEG6
Aug 20, 2005 06:29 AM
mozez
Jan 13, 2004 08:48 PM
1hotintegra
Nov 28, 2003 01:14 PM
v4lu3s
Aug 2, 2003 07:25 AM
Red99CivicSi
Jan 28, 2003 07:58 PM
