Motor overheated and i think i blew the headgasket
Old Sep 23, 2003 | 06:53 PM
Dorifto13B-T's Avatar
Default Motor overheated and i think i blew the headgasket
my b17 was overheating yesterday just driving around the fan doesnt work but it had never overheated before, it kept getting pretty high temps yesterday and then when i got home it jump into red and i turned the car off really quick. i hadnt started it up since till now and when i did it was smoking white from the motor area and muffler. blown head gasket?
Old Sep 23, 2003 | 07:07 PM
mickey513's Avatar
Default Re: Motor overheated and i think i blew the headgasket (wyt r1ce)
pretty simple to tell, just look at your coolant, do you see oil in it? If you do, then the headgasket is blown. Also, a blown headgasket will make a lot of white smoke come out of your tail pipe.
If neither of these are present, you can do a compression check.
Old Sep 23, 2003 | 07:10 PM
Default Re: Motor overheated and i think i blew the headgasket (mickey513)
the coolant seems straight, still green
Old Sep 23, 2003 | 07:26 PM
i checked the oil its good too
Old Sep 23, 2003 | 10:50 PM
Gerhard_001's Avatar
Check the spark plugs if they are white your head gasket is blown. Also you can pressure test the cooling system if you really want to know fast if your head gasket is blown, you can usaully have a mechanic do this for nothing or really cheap.
Old Sep 24, 2003 | 05:56 AM
Default Re: Motor overheated and i think i blew the headgasket (Gerhard_001)
nice ill try that
shm91
Sep 1, 2013 03:56 AM
highrollers23
Sep 2, 2009 06:54 PM
a3k
Jul 26, 2009 10:36 PM
bey
Jul 14, 2004 07:05 AM
Eg6_JDM
Aug 20, 2002 06:01 PM
