removing ac, can i get help ?
Old Sep 23, 2003 | 08:03 AM
TheAutoboxer
Guest
Posts: n/a
Default removing ac, can i get help ?
im swapping a engine soon, and im removing the ac/ps, i took off the ps pulley/motor, and the belt(done?) next the ac, i can remove the motor easy enough, but what about all thoose lines.. i'm pretty new with car work?
Old Sep 23, 2003 | 08:07 AM
tek_civic's Avatar
Default Re: removing ac, can i get help ? (menkio)
im not too sure what your asking, but if you have the pump off then you should be able to get the engine out, you might hit the condenser though(thing that looks like a 2nd radiator).
i heard its a lot easier to swap if you remove the ac condenser and the radiator, more room to work with and you won'y damage anything.
Old Sep 23, 2003 | 08:22 AM
TheAutoboxer
Guest
Posts: n/a
Default Re: removing ac, can i get help ? (tek_civic)
ohh i mean remove the ac all togther, i'm going turbo, and thars un-needed in boston
Old Sep 23, 2003 | 11:25 AM
BeerMan's Avatar
You have to drain the system, you should probably get a shop to do this, a/c fluid isn't fun to have in your eyes, or lungs. But if you want to do it yourself, (and risk respiratory problems and a fine from the EPA):
Take the cap off the bleed valve, should be just above the condensor, its a little blue cap, once the cap is off put a rag around it and push the valve down with a screwdriver. It's like letting air out of one's tire.
Next unbolt all the lines, these are the stiff lines covered in foam that run across and up the engine bay. That should take care of everything.
not sure if you need to plug any holes, though.
Old Sep 23, 2003 | 11:31 AM
SikofFalln's Avatar
Default Re: removing ac, can i get help ? (BeerMan)
Don't do it man! Keep the A/C! It is my biggest regret removing that.
pliskin679
Aug 11, 2010 01:25 AM
00EckoSI
24
Nov 29, 2009 07:52 AM
x_tuh_sy
Dec 11, 2007 05:08 AM
99fbpem1
Oct 13, 2007 05:52 PM
skribblez
Mar 18, 2005 07:56 PM
