Relocating battery
i have a question about relocating my battery. i need to relocate mine to the back due to my turbo kit, i was just wondering whether i still need to ground the battery to the engine block or not?
After I had problems starting the car in the winter I grounded it to the block and It was much better! I'm in Michigan though where winters suck big donky *****.
This was not on my lude though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">Hey man, where did you get your relocation kit from?? Any pics??
Thanks</TD></TR></TABLE>
I need to get on also
all i did was take the stock battery mounting and remove it, then I drilled holes for it in the trunk, put the stock mounting on, put the battery in and wired a power and ground through the car. i think i can get some pics...
Hey guys, I was just thinking about this. I was wondering if you can put a hiden switch to cut off ALL power so that it will make the car harder to steal. Just a thought.
I am sure you can do this...but i am wondering if it would be bad for the car in anyway?? Another reason why I want to do it is because of my 4WS issue. When the 4WS light comes on...I can get it to go off if I pull the stereo fuse or pull the battery cable.
Thanks
Thanks
hmmm not to sure about this one but i dont think you could find a heavy duty enought switch...maybe i'm wrong, you might want to run a relay to a switch...
boosted civic 2k6
Dec 4, 2005 01:30 PM
