what you guys think about "DIY" home alignment?
Old Sep 22, 2003 | 10:19 PM
im_the_teacher's Avatar
Default what you guys think about "DIY" home alignment?
i aligned my 97 accord tonite in my garage.....car feel great now, no more pulling....
what do you guys think about diy aligment? good or not a good idea?
i used the string and my eyes to align the wheels sstraight.
Old Sep 22, 2003 | 10:22 PM
iam7head's Avatar
Default Re: what you guys think about "DIY" home alignment? (im_the_teacher)
close doesnt court, get a real alignment and save those new tires
Old Sep 22, 2003 | 10:30 PM
Default Re: what you guys think about "DIY" home alignment? (iam7head)
heheheh......but alignment place dun have machine that can mount on my 18's
Old Sep 23, 2003 | 06:39 AM
kentucky accord's Avatar
ive been doing the driveway alignment for yrs. screw an alignment shop.......
Old Sep 23, 2003 | 07:48 AM
soodark's Avatar
could you guys explain how to do this? i'd love to save a few $$. thanks!
Old Sep 23, 2003 | 10:38 AM
Kavehman's Avatar
Yeah im also interested in how this is done. Can you give a brief description ???
Old Sep 23, 2003 | 10:06 PM
Default Re: what you guys think about "DIY" home alignment? (Kavehman)
yes diy alignment is easy..
need a level ground,,,and need sum metal plates for your tires to sit on
need a long string that go from rear of the car to the front...
connect the string to a stand (jack stand). or any.
get a ruller.
make sure your steering wheel is staight...
need: 14mm wrench....and 17mm or 19mm wrench to loosen the steering wheel tie rod nut.
now...make sure your string is straight from the rear to the front...then use the ruller to measure how bad your toe in or toe out..
after that loosen the tie rod nut and spin that rod in or out to adjust..
(make sure your steering wheell is straight while u doing this.
Old Sep 24, 2003 | 04:06 PM
jweller's Avatar
check this out
https://honda-tech.com/zerothread?id=597192
Old Sep 24, 2003 | 05:55 PM
fizzbob7's Avatar
Default Re: what you guys think about "DIY" home alignment? (jweller)
it's better than no alignment, but you'll never get it just right..... 1/2 a degree of camber is enough to eat your tires up depending on where it's at exactly....but some people are just cheap....$30 isn't that much......if it is, get a horse
Old Sep 24, 2003 | 07:15 PM
soodark's Avatar
sweet, thanks guys. I might try that next time my car starts pulling one way.
Old Sep 24, 2003 | 09:36 PM
NathanMorris's Avatar
Default Re: (soodark)
it's deffinately a lot better than no alignment, and for a lot of people getting a lowered car aligned is next to impossible, that and wheel size issues. It won't be as accurate as would a computer, but it's good enough for me...
- Nathan
Old Sep 25, 2003 | 10:26 AM
civicboisi's Avatar
Default Re: what you guys think about "DIY" home alignment? (fizzbob7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fizzbob7 &raquo;</TD></TR><TR><TD CLASS="quote">it's better than no alignment, but you'll never get it just right..... 1/2 a degree of camber is enough to eat your tires up depending on where it's at exactly....but some people are just cheap....$30 isn't that much......if it is, get a horse</TD></TR></TABLE>
Agreed!
bdmlilburn
Nov 14, 2011 02:17 PM
raidacaipo
20
Feb 27, 2010 03:05 PM
DJLikwid
Suspension & Brakes
Dec 24, 2007 09:19 AM
BadEH2
Jul 8, 2005 10:18 AM
Eee Pee
Jul 9, 2003 07:02 PM
