VAFC II tuning
I've looked around and did a few searches, but I'm coming up blank so I thought I would tap into the huge weath of knowledge that is the "All Motor forum"
Has anyone used the VAFC II to tune their car yet? I just got my Skunk2 stage2 installed and I'm trying to figure out weather I can just use the vafc II to tune it completely or if I should get myself a p28/p30 and ditch my JDM p72... The people at the shop that helped with the install recomend i get a p28 or p30 chipped with the skunk2 program... Any and all info will be helpfull!
Oh yeah and by the way, 6k-8.5krpm happens really ******* fast now and louder then I would really care for, but I wouldn't give it up if it ment loosing any of this new found power!
I would really take the car to a dyno to tune those cams. Those cams are really tempermental when it comes to tuning. As far as your tach goes, I used to rely on the stock tach in my 92 hatch until I put the new motor in. When I started to dog the new motor I noticed that the engine would run out of breath around 7000-7500 rpms on my stock tach. I checked my vafc and it reads 9500-9800 rpms!!! ( oh by the way, no rev limit), that tells me that my tach is off at high rpm. Hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bad-eg »</TD></TR><TR><TD CLASS="quote">I would really take the car to a dyno to tune those cams. Those cams are really tempermental when it comes to tuning. As far as your tach goes, I used to rely on the stock tach in my 92 hatch until I put the new motor in. When I started to dog the new motor I noticed that the engine would run out of breath around 7000-7500 rpms on my stock tach. I checked my vafc and it reads 9500-9800 rpms!!! ( oh by the way, no rev limit), that tells me that my tach is off at high rpm. Hope this helps.</TD></TR></TABLE>
it's just the opposite with mine, my tach(stock vx cluster) reads 8k rpms and my VAFC II read 7400rpms....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMac86 »</TD></TR><TR><TD CLASS="quote">Question regarding a p28, would a p28 chipped with the skunk2 program run correctly on a d16y8 SOHC? Thanks!</TD></TR></TABLE> I'm sure you gan get a p28 chipped for a shoc engine, infact it might come stock in a few cars... The one I was told I need needs to be chipped for a DOHC vtec engine with a single stage intake manifold
Sounds like I am in a similar boat as you, except I cant figure out if I should get the P28 first, or if I should get a VAFC and get the car tuned. I do not have the budget to do both at this current point in time.
BoostedGSRBubble
Jun 19, 2002 08:38 PM
