anyone solve that idle dropping prob. when clutch is in??
its that common prob when you push the clutch in while driving the idle will drop all the way down then back up to stock.. my car does it. it has shut off like 3 times now but only at like LOW speeds. i heard that its just one of those things you cant really fix. i have never tried. anyone ever get it worked on to where it just drops down the stock idle.
i am at like 5000 RPM just cruising. and i push the clutch in. the rpms drop all the way down to about 100, then goes back up to 900 (my idle)
thanx
thanx
throttle plate as in butterfly right.
well, maybe i should first clean out the TB. my gas pedal gets stuck sometimes. i am thinking that has to do with it.
If your throttle sticks open up your throttle plate a little more. That might be doing it to.
Yes throttle plate / butterfly
kewl.. well i just found out that my TB doesnt have that screw that adjusts the plate. i got one now and im gonna put the screw in and see if things will improve.
thanx
thanx
well, i put that little screw in. i opened it up. still didnt work. i even had it opened it up to where i was idling at 2K RPM and it still dropped down to about 200 RPM then went back up. ima clean the TB tomorrow.
What minimum voltage reading do you get from the tps sensor? Compare that to specs in a manual (OEM) If its lower than factory specs, .45v ( I think? , someones borrowing my manual) that could cause a fuel cut and drop the idle.
i "fixed" my problem with replacing the ecu...try it and see if it helps....now im running non vtec
not fun at all!!!!
not fun at all!!!!
sevenfc
Feb 28, 2009 11:55 AM
