Where can I tap for my Autometer Oil Pressue gauge with that 1/8 nylon line?
Old Sep 22, 2003 | 09:50 AM
freeplay's Avatar
Default Where can I tap for my Autometer Oil Pressue gauge with that 1/8 nylon line?
Any ideas? I'm sure you all know of the "supplies" they give you in the box, but I don't see and 1/8 or 1/4 line like I did with my boost gauge. Any help? Thanks in advance!
Old Sep 22, 2003 | 12:10 PM
WOTTEG's Avatar
Default Oil Pressure Gauge Adapter fittings diagram links
The stock oil pressure switch is located to the left of the oil filter [when viewed from under the engine]. The switch is covered with a rubber boot that looks like a Hersey's Kiss. You can tug on the boot to remove the wire, and use a deep socket (22mm or 24mm) to remove the switch. You will have to follow the diagrams in the post below in order to install the gauge "correctly".
https://honda-tech.com/zerothread?id=246839
https://honda-tech.com/zerothread?id=247706
90blackcrx has images of the sending unit and stock oil pressure switch mounted to the firewall:
https://honda-tech.com/zerothread?id=600972
Old Sep 22, 2003 | 12:16 PM
Double121's Avatar
Default Re: Where can I tap for my Autometer Oil Pressue gauge with that 1/8 nylon line? (Civic@7psi)
Its either Endyn or GE that sells an adapter that goes on before the oil filter to allow you to connect things like a oil pressure gauge.
Old Sep 22, 2003 | 01:39 PM
freeplay's Avatar
Default Re: Where can I tap for my Autometer Oil Pressue gauge with that 1/8 nylon line? (Double121)
Thanks a lot guys. I'll try that. Please post something still if you have anything more simple maybe that works as well. Thanks again
Old Sep 22, 2003 | 03:16 PM
WOTTEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic@7psi &raquo;</TD></TR><TR><TD CLASS="quote">Please post something still if you have anything more simple maybe that works as well.</TD></TR></TABLE>
The only thing that makes this "difficult" is sourcing the parts. Call Marylad Metrics for the NPT &gt; BSPT BSPT &gt; NPT Adapters that you need.
If you find a "simpler" way, I'll gaurantee it has faults. And while you are at it, buy an electric gauge with sender instead of the mechanical one. Does 200 degree oil splashing about in your cabin sound like fun?
The first oil presure gauge I installed was mechanical. I quickly removed it after reading a couple posts (2 years back) about the gauge line coming loose in the cabin. In one instance the cabin was sprayed with oil, the other instance it merely dripped oil behind the dash and went unnoticed for until the smell became prevalent.
I know there are TONS of people that this does not happen to, (I am included) but I'd hate to be the 1/1000 tha it does happen to. Electric gauges eliminate that risk.
Good Luck.
Old Sep 22, 2003 | 03:35 PM
freeplay's Avatar
Default Re: Where can I tap for my Autometer Oil Pressue gauge with that 1/8 nylon line? (WOTTEG)
i heard they weren't as accurate though. True?
Old Sep 22, 2003 | 09:56 PM
T4eg's Avatar
Default Re: Oil Pressure Gauge Adapter fittings diagram links (WOTTEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WOTTEG &raquo;</TD></TR><TR><TD CLASS="quote">The stock oil pressure switch is located to the left of the oil filter [when viewed from under the engine]. </TD></TR></TABLE>
Old Sep 23, 2003 | 10:04 AM
WOTTEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic@7psi &raquo;</TD></TR><TR><TD CLASS="quote">i heard they [electric] weren't as accurate [as mechanical] though. True?</TD></TR></TABLE>
Haven't heard that. That may be in reference to non-full-sweep electrical gauges, where the PRECISION (not accuracy) is not as fine as a full sweep mechanical gauge. But that's apples and oranges.
EFityo
Feb 17, 2011 04:48 AM
nicko360
Mar 14, 2007 02:52 PM
civicridah
Jul 17, 2003 12:09 PM
FastNFurious
Apr 26, 2003 09:52 PM
tuphatt
Mar 3, 2003 06:31 AM
