Busted Fuel line
Old Sep 22, 2003 | 05:50 AM
Muckman's Avatar
Moderator in Chief
Default Busted Fuel line
Busted the main fuel line going into the filter from the pump on a '01 Prelude. I need some ideas on how to fix this: I need the fastest/easiest solution.
- Should I replace the entire line with steel braided pipe from the pump to the filter?
- Can I repair the end of the fuel line somehow? I was thinking possibly a small length of steel braided line from the metal pipe up to the filter. Would that be prone to leaking?
The break is where the line screws into the fuel filter. It was overly tight from the factory and twisted when I tried to change out the filter.
Old Sep 22, 2003 | 08:36 AM
Muckman's Avatar
Moderator in Chief
Default Re: Busted Fuel line (Muckman)
Help
Modified by Muckman at 1:13 PM 9/22/2003
Old Sep 25, 2003 | 10:01 AM
dwolsten's Avatar
If the car's an '01 Prelude, it should still be under warranty. You may be able to file a warranty claim for it, though you'll probably have to argue with them that you didn't break it and it was because of overtightening at the factory.
Old Sep 25, 2003 | 10:08 AM
b20turbojason's Avatar
there is a way that you can reflare the metal line and put a new fitting on it but i have always had that done at napa. so you might have to take the whole line out unless you cn get youre hands on the that tool used to flare the line out with. it will be a little short and you will have let the filter hang but you said quik and easy right
Old Oct 3, 2003 | 11:35 AM
Muckman's Avatar
Moderator in Chief
Fuel Line Repair kit from Advance Auto Ownz me
5/16"
ODbuilt
Apr 26, 2014 12:50 PM
nWilk666
Feb 1, 2012 12:01 PM
memphisfuk
Jun 8, 2008 01:20 PM
HondaKid936
Jun 5, 2008 06:48 AM
2-7offsuit
May 25, 2006 01:38 PM
