Brembo Brake Rotors - having problems now.
Anybody here have a set of Brembo cross-drilled stock-sized rotors on their 4th gen? I have had mine for over 9 months. I have had 2 different set's of Rota's on them, the SLIPS, and the C8's, have had the 99-00 SI stocks on them, then the 01 LS stocks. All fit perfectly fine, then I ended up with a set of 99GSR blades and I am having problem fitting the wheel onto the front driver side. It does not slide fully over the little groove that rises up on the rotor? I do not understand why it seems larger now. Would it be safe to grind it down so it doesn't even stick up? Any help is greatly appreciated. THanks
Are you absolutely certain about the rim. A minor problem with the clearances involved can do this. Do not machine the hub or rotor. Carefully inspect the hub and mating surface on the wheel. I have Brembo Blanks on the CRX with MR12's and no problems with either them or the stock Si wheels.
I'm positive, I even tried a 15" stock steel wheel and it would not fit. I can't imagine the LS or SI stocks being much different as to where the GSR wheel doesnt fit correctly.
mojoGSR92
May 28, 2006 10:55 AM
allmotorEG-SI
Dec 12, 2003 06:02 AM
