Power gains
Old Aug 23, 2001 | 03:23 PM
Luke's Avatar
Default Stuff
All,
I want to get more power from my 97 ITR. I have looked into a full Mugen setup but am toying with the idea of ripping the cat out. I dont care about emmissions as i can replace for the MOT every year............anyone?.
Next what is the best route to stabilising the back of the car which tends to be a little light when you push it.....camber setup?
[Modified by luke, 12:26 AM 8/24/2001]
Old Aug 23, 2001 | 04:29 PM
STOLEN - ITR 98-0652's Avatar
Default Re: Stuff (luke)
And here I thought that light rear (oversteer) was a good thing... My R only seems to break loose under very heavy braking (at ABS threshold).
(shrug)
Old Aug 23, 2001 | 06:29 PM
Bob#455's Avatar
That lightness in the rear end is a characteristic trait of the Type R....don't get rid of it, just learn to use it to your advantage. Lift off oversteer is a good thing if you know how to use it.
Luke's Avatar
Default Re: Stuff (ITR 98-0652)
Dont get me wrong mate, it's a laugh to drive but it is exactly under braking when it is a pain, i have heard that King Motorsports do some arms help?????, do you have any info on what the cat will do?
Old Aug 23, 2001 | 06:31 PM
Bob#455's Avatar
King's lower control arms are meant to be used on GSRs when installing the Mugen Lowdown suspension.
Old Aug 23, 2001 | 06:33 PM
Bob#455's Avatar
Getting rid of the cat will get you about 3-4 whp, I think.
Old Aug 23, 2001 | 06:35 PM
Luke's Avatar
Default Re: Stuff (Bob#497)
mmm, worth a try. I guess i need to put it on a track to experiment before i go spinning into a hedge!!!
Old Aug 23, 2001 | 06:46 PM
Big Phat R's Avatar
Switching to stiffer springs will reduce the dive under hard braking and improve transitional response of the car - which is a tad soft for my liking. I found the stock suspension allowed the rear end to get "squiggly" under really hard braking. If you get height-adjustable coil-overs, you can play around with the height of the rear (which is pretty 'high') and ultimately change the center of gravity. I did, and got a great improvement over stock.
The sensations you feel may be due to the stock set-up of front linear rate springs and rear progressive, which tends to be tuned for understeer and safe, predictable handling at 8 to 9/10s but at 10/10ths is a little scary. If you want to go faster and improve handling - lowering the car a couple of inches really makes an improvement - plus you get more aggressive camber which helps out with cornering/turn in.
Also, I found the Mugen adjustable rear wing to have a great stabilizing effect (at fast speeds > 80 km/h) if you set the spoiler to maximum downforce.
[Modified by Big Phat R, 7:47 PM 8/23/2001]
Old Aug 23, 2001 | 06:53 PM
Luke's Avatar
Default Re: Stuff (Big Phat R)
How much is safe to drop it without all the crap with arches.. i spose that it depends on the shocks? cool info. cheers
Old Aug 23, 2001 | 07:12 PM
Big Phat R's Avatar
If you retain the stock shocks, don't lower it a ton. Aftermarket shocks are recommended in most cases.
Old Aug 23, 2001 | 07:36 PM
99ITR_SC's Avatar
Except in BEER cases....
Old Aug 23, 2001 | 07:58 PM
Luke's Avatar
Default Re: Stuff (99ITR_SC)
Oh dear
mdb4879
Oct 9, 2018 04:14 AM
Tjabo
Sep 27, 2007 08:45 AM
llxzxll
20
Apr 8, 2005 02:05 PM
Bailhatch
Mar 21, 2004 08:49 PM
JDM_Type-R
May 13, 2002 12:09 PM
