Turbo Accord Injector Question
Anyone with a turbocharged Accord: what size injectors are you running, how much boost are you running, and what are you doing for fuel pressure and fuel management? What are the largest injectors that can be run without too many problems on the stock ECU? I tried searching but there isn't too much for Accords.
Thanks. A friend of mine is going to sell me his 550s off of his DSM. Any idea how much power you're putting down right now? I was also thinking of getting a Hondata. How do you like it? Also, what kind of fuel pump are you running?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtmamg »</TD></TR><TR><TD CLASS="quote">Thanks. A friend of mine is going to sell me his 550s off of his DSM. Any idea how much power you're putting down right now? I was also thinking of getting a Hondata. How do you like it? Also, what kind of fuel pump are you running?</TD></TR></TABLE>
215 hp 238tq.. @ 11psi with stock cat but i let off at 4.5 rpms due to boost spike...
definitely get a hondata.. feels like a boosted car that came from the factory.. very smooth transition to boost.. no hesitations at all..
i'm running a walbro 255lph fuel pump
Thanks for all the info. I'll be getting a Hondata sometime soon. Right now, I'm looking for another F22A to build up and then drop in. Anyone know where to get oversized valves? I've looked and I haven't seen any offered by Crower, Crane or Ferrea for the F22A, just F22B. Also, what size turbos are you all running?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boonacka »</TD></TR><TR><TD CLASS="quote">are all you guys running stock bottom ends?</TD></TR></TABLE>yes
yes..
numbers... scroll up
yes..
stock f22b1 auto (except skunk2 cam gear)
dsm 450cc
10 psi
stock fuel pressure
hondata 2b
walbro 190lph intank fuel pump
215 whp 195 tq
dtmamg, have you gotten anything so far for your turbo setup..?
dsm 450cc
10 psi
stock fuel pressure
hondata 2b
215 whp 195 tq
hey i had a f22a6 and i was hitting around max of 13psi but running a stable 7to8psi how much power u think i was putting down till i blew up the motor? hp wise?
Calvinator
Jul 30, 2006 09:03 AM
frostcivic
Aug 6, 2004 02:22 PM
