higher compression
Old Sep 21, 2003 | 01:13 PM
prdtr15's Avatar
Default higher compression
can i raise compression at all without changing the pistons? bc i was told that i could, but i have no idea
Old Sep 21, 2003 | 01:31 PM
blueeg's Avatar
Default Re: higher compression (prdtr15)
yes u can
Old Sep 21, 2003 | 01:57 PM
RCautoworks's Avatar
Default Re: higher compression (blueeg)
You can get a thicker head gasket.
Old Sep 21, 2003 | 02:02 PM
User 5426's Avatar
Default Re: higher compression (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">You can get a thicker head gasket.</TD></TR></TABLE>
If I am not tripping, shouldn't thicker head gaskets lower compression????
Old Sep 21, 2003 | 02:20 PM
Default Re: higher compression (SeaQuake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeaQuake &raquo;</TD></TR><TR><TD CLASS="quote">
If I am not tripping, shouldn't thicker head gaskets lower compression????</TD></TR></TABLE>
Yeah your right, I was not thinking correctly.
Old Sep 21, 2003 | 02:36 PM
t04ecvc's Avatar
You can mill the head, but why. You can only mill/deck a head so much. You can get a single layer head gasket, but why. This will only decrease reliablility in the long run. The few ways you can raise compression without changing pistons will not give a big enough gain to really notice it.
Old Sep 21, 2003 | 03:18 PM
Big Teggie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prdtr15 &raquo;</TD></TR><TR><TD CLASS="quote">can i raise compression at all without changing the pistons? bc i was told that i could, but i have no idea</TD></TR></TABLE>
Yes you can.
Mill the head
Deck the block
Thinner headgasket
Old Sep 21, 2003 | 03:35 PM
TimoneX's Avatar
New User
Default Re: higher compression (t04ecvc)
Flat faced valves lower the cc volume somewhat and will boost compression slightly as well. All these tricks together can yield right around a full point(including a mild milling job) on a B18C, that IS enough to be noticable.
Old Sep 21, 2003 | 06:14 PM
LudeyKrus's Avatar
Default Re: higher compression (Big Teggie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie &raquo;</TD></TR><TR><TD CLASS="quote">
Yes you can.
Mill the head
Deck the block
Thinner headgasket</TD></TR></TABLE>
Plus the aftermarket valves that bump compression. I see nothing wrong w/ any of these ways, but w/ decking/milling, you better not change your mind afterwards!
Old Sep 21, 2003 | 09:12 PM
mr.beeks's Avatar
Default Re: higher compression (LudeyKrus)
dont forget that after you mill the head or deck the block
timming on your cams will be different
so take it to a professional
otherwise you are going to overheat
check this site
http://www.c-speedracing.com on the how to section plenty of info for you
Old Sep 25, 2003 | 03:45 PM
t04ecvc's Avatar
Default Re: higher compression (TimoneX)
After going through all the trouble of milling, changing valves and so on, he might as well just change the pistons. Also, I don't think that the valve change will have a very big difference in compression. But the thinner head gasket will yield a noticable change ( thought about it after posting initially ) I talked to REV about their flat valves and they said that they would yield about a .1 change in compression on a gsr head. Good luck on your project
ProjectBB6
Mar 13, 2008 09:24 AM
melovesboost
Feb 18, 2007 07:27 AM
pulpdeem
Feb 14, 2006 07:32 AM
2point3h22lude
17
Jun 9, 2005 03:47 PM
p1ccoloz
Apr 21, 2003 09:41 AM
