valve cover gasket , , ,
Old Sep 21, 2003 | 01:04 PM
JBBNJ609's Avatar
Default valve cover gasket , , ,
im doing a valve adjustment , need this , what part # is it , and can i get a preformace one ( dont flame me , i was thinking i could get one like a head gasket and up my compression , dont laugh just say yes , no or link please)
(94 gsr)
Old Sep 21, 2003 | 02:03 PM
VTECorona's Avatar
Default Re: valve cover gasket , , , (jason bouchard)
you don't always need a new one, only if it is deteriorated or messed up in any way. just go to the dealership and ask for a valve cover gasket for a B-series motor if urs is bad.
Old Sep 21, 2003 | 04:00 PM
JBBNJ609's Avatar
Default Re: valve cover gasket , , , (VTECorona)
ok kool, what about this liquid stuff i hear about on this site , like to be near the cam plug or somthing plastic like that . ..
Old Sep 21, 2003 | 05:35 PM
VTECorona's Avatar
Dunno man.. but use some thread locker on the valve cover nuts when you put them back on.
Old Sep 21, 2003 | 05:41 PM
B2FiNiTY's Avatar
You will need Honda bond otherwise it will leak when you put it back on. It seals the rubber to the head.
Old Sep 21, 2003 | 05:44 PM
JBBNJ609's Avatar
Default Re: valve cover gasket , , , (B2FiNiTY)
where do you buy that , besides the dealer ( can you buy it from the dealer)
Old Sep 21, 2003 | 06:28 PM
Rory Breaker's Avatar
You can get gasket sealant at your parts store. Just dab some on the flat spots of the gasket. Be careful not to tear it when taking it off, and be sure its on correctly when you torque down the VC, and you should be able to reuse it numerous times.
Old Sep 21, 2003 | 06:46 PM
timmy8151's Avatar
Default Re: valve cover gasket , , , (newgsrdriver)
Also, don't overtighten the bolts as they are prone to snapping. Tighten down the nuts in a couple of steps and torque it down to 7.2 lb-ft.
Old Sep 21, 2003 | 06:48 PM
X2BOARD's Avatar
Default Re: valve cover gasket , , , (timmy8151)
btw... i mighta read it wrong... but you may be confusing your valve cover gasket with a head gasket. Valve cover gasket doesn't affect compression.... and is 100 times easier to replace...heh heh heh...
Old Sep 21, 2003 | 08:11 PM
blown_LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver &raquo;</TD></TR><TR><TD CLASS="quote">You can get gasket sealant at your parts store. Just dab some on the flat spots of the gasket. Be careful not to tear it when taking it off, and be sure its on correctly when you torque down the VC, and you should be able to reuse it numerous times.</TD></TR></TABLE>
Yup !!!
Old Sep 21, 2003 | 09:16 PM
JBBNJ609's Avatar
Default Re: valve cover gasket , , , (X2BOARD)
o , yea i prob am , but i got some pics and noew i see what they both are ( valve gasket is likes REAL easy to replace and looks alot diff then the other one . . . thanks
miksew
13
Oct 20, 2006 05:48 PM
-Championship-
Jun 29, 2006 10:59 PM
type Gendy
10
Sep 6, 2003 10:44 AM
Qwikrex
Nov 18, 2002 02:13 PM
hb_racer
Aug 4, 2002 11:58 AM
