timing on the distributor
Old Sep 21, 2003 | 02:19 AM
mr. wu's Avatar
Default timing on the distributor
i was wondering how many degrees i could retard or advance my distributor, either way from the stock setting, so the middle i guess. someone told me it was 7 degrees either way, is this true or not.
Old Sep 21, 2003 | 02:40 AM
timmy8151's Avatar
Default Re: timing on the distributor (mr. wu)
On a stock car, you really shouldn't advance your timing more than 2 degress either way.
Old Sep 21, 2003 | 03:15 AM
Green94GSR's Avatar
Default Re: timing on the distributor (timmy8151)
Every thing I have heard would agree with this. What is the purpose?
Old Sep 21, 2003 | 12:27 PM
mr. wu's Avatar
Default Re: timing on the distributor (Green94GSR)
i am runing 12:5:1 compression and i have a timing retard just to be safe for when i run on pump gas, i need to know how many degrees the distributor can be adjusted so i can figure out where i should set my timing from inside the car.
Old Sep 21, 2003 | 07:59 PM
mr. wu's Avatar
come on guys, i know sombody knows for sure.
Old Sep 22, 2003 | 11:10 AM
mr. wu's Avatar
are you serious, 53 views and no one knows the answer to this question
Old Sep 22, 2003 | 11:18 AM
havok hybrid's Avatar
I have heard that it was +5 or -5 that you have to work with at the distrubtor.
There has to be someone out there that know this.... is it +5 -5 or it is +7 -7.
Come on playa's Help this MO FO out ... !!!
Old Sep 23, 2003 | 01:36 PM
mr. wu's Avatar
Default Re: timing on the distributor (havok hybrid)
come on people help me out
Old Sep 23, 2003 | 06:29 PM
gamakichi77's Avatar
you should use a timing lights for accurate settings. try this http://www.c-speedracing.com you can learn how to use a timing light inside it. enjoy yourself
Old Sep 23, 2003 | 06:48 PM
mr. wu's Avatar
Default Re: timing on the distributor (acidburns_di)
i don't think that a timing light is going to help, all i need to know is how many degrees i can advance or retard my distributor
Old Sep 23, 2003 | 06:59 PM
95GS-Racin's Avatar
I think I remember reading somewhere that you can adjust it + or - 7. But dont quote me on this.
Old Sep 23, 2003 | 07:19 PM
mr. wu's Avatar
Default Re: timing on the distributor (95GS-Racin)
i have also herd that you can ajust it + - 7 but i just need a for sure answer, thanks for the info
prodjay10
11
Mar 28, 2015 09:07 PM
tobster
Engine Management and Tuning
Aug 20, 2010 05:55 AM
brusk13
Jan 11, 2006 07:01 PM
98slvrcx
Jul 28, 2002 09:58 PM
you2envious
Jun 5, 2002 07:50 PM
