NEED HELP on my System Set-Up
Okay no flaming!!....not too car audio savvy so i need some help/information.
Car Audio stuff i have so far:
Pioneer Premier DEH-P 650 Headunit
Pioneer TS-a6970r 6x9 3-way Speakers in the rear(240 watts 40watts rms)
12" Pioneer TS-w304dvc - 300watts rms 600 watt max
Performance Teknique ICBM-892 2 channel 1000 watt amp
Car Amplfier (ICBM892) Features:
Max Power Output: 1000W @ 2 ohms
Max Output Power: 125W @ 2ch @ 4 ohms
Power Output: 175W @ 2ch @ 2 ohms
Power Output: 350W @ 1ch bridged
24dB Crossover
Variable Low Pass Filter (30Hz-500Hz)
Variable High Pass Filter (50Hz-1KHz)
Variable Bass Boost (0-18dB)
Variable Subsonic Filter (10Hz-100Hz)
Wired Bass Remote Control
RCA Line Output
Double Sided PCB
High & Low Level input
Two Way Protection
Tri Mode Speaker Connection Stable
2 ohm Stable Stereo
Soft delayed Power on
0.05% THD
Stuff on the way right now:
Just ordered 6-1/2" CDT Audio CL-61a components and should be here early this week.
My question is what to do about my amp? is this thing gonna be able to power my sub and components? Right now i have it bridged and its powering only my sub right now. I was thinking of just dumping this amp and getting a LANZAR amplifier. Not sure which one would be good to power all off this. And i'm thinking of adding one more 12" sub the same type to my system in the near future. So I'mma need to power all of this. In a car audio dilemna! Any help would be great. Oh yeah ...should i get a capacitor also?
Jeff
24dB Crossover
RCA Line Output
Double Sided PCB
Two Way Protection
2 ohm Stable Stereo
0.05% THD
Jeff
i GUESS you could put both on that one amp, the 2 components on 1 channel and the sub on the other channel, the problem would be putting too much power to your components, the 2 channels are gonna put out the same amount of power so whatever you put on your sub is also gonna be on your components, keep that in mind, i'd go with a little cheapy 2 channel amp for your components, and a cap. really won't do much unless you have a 2 bigger amps
