pickin an amp ...
Old Feb 4, 2002 | 11:15 AM
91 slow civic's Avatar
New User
Default pickin an amp ...
What would you guys recomend.....
The american Pro-
HIGH POWER 1600 WATTS
LEFT AND RIGHT VU METERS ON TOP OF AMP
2 OHM STABLE
BRIDGEABLE AND TRI MODE CAPABLE 2, 3 OR 4 CHANNEL
FAN COOLING SYSTEM
VARIABLE BASS BOOST 0 TO 18DB
LOW PASS FILTER
HIGH PASS FILTER
VARIABLE BASS FREQUENCY 5 TO 100 HTZ
CHANNEL SEPARATION >60DB
SIGNAL TO NOISE RATIO >97DB
FREQUENCY RESPONSE 20HZ TO 200KHZ
HIGH AND LOW LEVEL INPUTS WITH ADJUSTMENTS
MOSFET DC-DC SWITCHING POWER SUPPLY
LED INDICATED POWER STATUS
BUILT IN PROTECTION AGAINST SHORT CIRCUIT AND HIGH TEMP
REMOTE ON AND OFF
300MM X 53MM X 613 MM
[IMG][/IMG] http://salesco.com/amps/americ3.jpg [IMG][/IMG]
INTERNET SPECIAL $299.95
Or ....
The Detenater.....
1800 WATT MOSFET CLASS A POWER AMPLIFIER. 2 OHM STABLE AND YOU CAN RUN THE AMP IN 2, 3 OR 4 CHANNEL MODE. CHECK IT OUT THE TOTAL HARMONIC DISTORTION IS LESS THAN 0.03% AND THE TOTAL POWER OUT PUT IS OVER 1800 WATTS. THIS ONE GOES BOOM!!!! GOLD PLATED RCA JACKS AND POWER AND PROTECTION INDICATORS. THIS AMP IS FULLY BRIDGEABLE AND HAS AN ADJUSTABLE GAIN CONTROL. HIGH LEVEL INPUT DIRECT FROM THE SPEAKER WIRES OR USE THE RCA INPUTS. CHANNEL SEPARATION IS BETTER THAN 75 dB AND THE SIGNAL TO NOISE RATIO IS CLOSE TO 100 . AMP HAS REMOTE ON AND OFF AND SOFT TURN ON. THIS IS A GREAT AMP AT A GREAT PRICE..
http://salesco.com/amps/amp1600.JPG
INTERNET SPECIAL $285
The amp will be goin on a 18" Rockford Fosgate, in a civic Sedan. Will it bag with this kinda power on it?
[Modified by 91 slow civic, 8:22 PM 2/4/2002]
Old Feb 4, 2002 | 05:29 PM
SiClone's Avatar
Default Re: pickin an amp ... (91 slow civic)
Pass on both of those and get something like Rockford, PPI, JL, Phonix Gold, or Memphis.....
Those two amps are junk and for $300, you could do much better. Just look on ebay.
Old Feb 6, 2002 | 11:09 AM
taisondiep's Avatar
what are u running on the amp.tell me what u running and ill tell u the best set up.and i can get the best prices
Old Feb 6, 2002 | 12:54 PM
froggie3kb's Avatar
I would look into MA audio, they have some awesome amps that put out gobs of power and dont cost an arm and a leg, I have MA audio's HC2501 and i love it to death, it'll put out some good power for only 200$ brand new, 1250 watts to be exact, lol. check out their website.theirs some awesome prices on their stuff on Ebay. They have a webboard on their website if you wanna hear other people stories. http://www.maaudio.com . Just make sure to research into whatever you get, and try to find people with the product to see if they like it, well i'll shutup now hope this was of some help.
OPTION2ek V.2
Northern California (Sales)
14
Mar 20, 2007 10:29 PM
jeeeezy
May 22, 2006 08:31 PM
GundamONE
Audio / Security / Video
Sep 21, 2003 09:52 AM
