spring compressor problem....
Old Sep 20, 2003 | 08:13 PM
Lei Siew Long's Avatar
Default spring compressor problem....
i'm putting a set of stock Accord springs back on and after compressing the spring with an impact gun, putting the top hat back on and decompressing it, the spring is never straight. it tends to be bent to one side no matter how many times and how many different methods i use.
i'm using a spring compressor rental from AutoZone. i would appreciate some helpful hints or tips.
Old Sep 20, 2003 | 09:19 PM
TimoneX's Avatar
New User
Default Re: spring compressor problem.... (Hatch4urSnatch)
Spring not seated properly? Wrong spring...too long perhaps?
Old Sep 20, 2003 | 10:46 PM
Default Re: spring compressor problem.... (TimoneX)
the bottom of the spring is against the perch. the spring does seem a little long but, i'm not sure if this is the correct spring because these springs are for a 96 accord and i'm trying to get it to fit a 91 accord.
Old Sep 20, 2003 | 11:58 PM
Starrman85's Avatar
i would think they are the same spring, since when you buy aftermarket springs, they are for the 90-97 accords, so they use the same aftermarket spring.
other then taht, i dont kno what to tell ya man. good luck tho.
Old Sep 21, 2003 | 10:47 AM
Default Re: spring compressor problem.... (STARRMAN85)
thanks.
TTT
Old Sep 21, 2003 | 02:15 PM
haccord2.2's Avatar
yeah I have had that problem with the stock springs on my old 96 accord, I put it all back to stock when I sold it, and even used Autozone spring compressors too! Well anyways, as long as the spring is in the bottom spring perch and upper spring perch, and the springs look cocked or what ever when you install the assembly on the car and drive it they should settle themselves to look like they should. Thats what I did and they worked for me shouldn't be any problem. Well hope this helps, Jordan.
Old Sep 21, 2003 | 06:12 PM
LudeyKrus's Avatar
Default Re: spring compressor problem.... (haccord2.2)
There should be a little notch where the end of the spring sits on the perch; make sure the spring's end is in that notch.
Other than that, if you had to compress the spring down hard, then it may just need to settle back out once it's ridden on some. Don't worry about it.
soeurm
Suspension & Brakes
Jan 12, 2007 10:04 AM
Wazup
Suspension & Brakes
Jan 29, 2006 02:11 AM
Sean @ ESG
Suspension & Brakes
Nov 23, 2005 01:22 PM
NA95d16z6
Suspension & Brakes
29
May 5, 2005 09:40 AM
itr157
Feb 25, 2002 04:55 PM
