electrical problem...need help!!
Old Sep 20, 2003 | 07:02 PM
Juan Q...'s Avatar
Default electrical problem...need help!!
i have a 1991 acura integra ls...the problem is that when i try to turn the motor, the starter clicks once and then does nothing...if we push start the car i will work, but will not start with the key...i have tried to to run the signal to the starter straight from the battery, also have tried about 4 starters thinking that is the problem , but nothing works. i tested the black/white wire under the dash and it powers up when the key is put in the start position, but when i test the same wire at the starter i don't get no power...if anyone has had this problem or anything like it please help.......thanks in advance
Old Sep 20, 2003 | 09:39 PM
TimoneX's Avatar
New User
Default Re: electrical problem...need help!! (obdjuan)
Turn your headlights on and then try to start it. If your headlights drop to almost nothing then your starter is being supplied with adequate power and either it's fragged or it's jamming against the flywheel. To test the later put the car in gear with it off(of course) and rock it back and forth a bit or tap the starter casing lightly with a hammer. If it still won't start after that then remove the starter and inspect the pinion gear. Eventually the solenoid spring gets tired and just doesn't properly engage the gear to the fly anymore.
Sorry I didn't read your entire post before shooting off my mouth. If you've already tried a few different starters did you have a look see at the flywheel teeth? Perhaps they're damaged to the point they're not allowing the starter to engage.
Old Sep 22, 2003 | 07:55 PM
Taco Sauce's Avatar
please help my car.
Old Sep 22, 2003 | 08:21 PM
ultimatehonda's Avatar
Have you checked all the wires and fuses? Did you check the starter relay?
Old Sep 22, 2003 | 08:36 PM
jerseybrandon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obdjuan &raquo;</TD></TR><TR><TD CLASS="quote"> i tested the black/white wire under the dash and it powers up when the key is put in the start position, but when i test the same wire at the starter i don't get no power...if anyone has had this problem or anything like it please help.......thanks in advance </TD></TR></TABLE>
chase the black/white wire, that sounds like the problem so far. its dropping the voltage somewhere.
Old Sep 22, 2003 | 08:40 PM
Mochanic's Avatar
sounds like a bad battery, or battery connection, or a bad ground wire to the motor... have someone check for a spark at all the major connections when you try to start the engine. (it will only spark when you hear the click if this is what it is.) If you do see a spark, this is where your bad connection is!
Modified by Mochanic at 11:59 PM 9/22/2003
Old Sep 22, 2003 | 08:54 PM
4crx4me's Avatar
Default Re: electrical problem...need help!! (Mochanic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mochanic &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a bad battery, or battery connection, or a bad ground wire to the motor... have someone check for a spark at all the major connections when you try to start the engine. (it will only spark when you hear the click if this is what it is.)
I have had the same exact problem a few times. IF you get NO power AT ALL. Then you have a bad connection at the batt. ground or a bad neg batt. cable.
Try wiggling the neg cable see what happens and check where it bolts to frame rail for rust or corrosion.
HTH.
Old Sep 23, 2003 | 10:32 AM
Taco Sauce's Avatar
Thanks for all of the help guys. I really do appreciate it. Hopefully my car will be up and running again real soon.
-thomas
uniquerider
Aug 12, 2015 11:00 PM
gooblinn258
Dec 16, 2013 08:23 AM
JasperThomas
Nov 20, 2010 10:29 PM
pooorman's type-r
Oct 7, 2008 03:07 PM
elpermgrande
Aug 9, 2002 06:43 AM
