Stipped fuel rail thread!!
Old Sep 20, 2003 | 01:45 PM
turboxsi's Avatar
Default Stipped fuel rail thread!!
One of the three threaded holes for holding down my fuel rail is stripped, so there are only two bolts tighted down, holding on the fuel rail. I've had no leaks so far, and was wondering if it will be ok like this.
I just got this itr manifold installed and don't want to have to remove it to rethread the hole or replace the whole manifold. This ever happen to anyone?...please help!!!
Old Sep 20, 2003 | 01:57 PM
mmuller's Avatar
Mad Scientist
Default Re: Stipped fuel rail thread!! (turboxsi)
it'll be fine, but you can just replace the stud
Old Sep 20, 2003 | 02:09 PM
turboxsi's Avatar
Default Re: Stipped fuel rail thread!! (mmuller)
I removed the studds and spacers so the injectors would sit right and used bolts to hold down the fuel rail. Its a 1st gen b16 w/ itr i/m and GS-R fuel rail. Its the actually threads the stud would screw into on the i/m that are stripped. Can i re-thread it??
Old Sep 20, 2003 | 04:29 PM
mmuller's Avatar
Mad Scientist
sure, tap it
Old Sep 20, 2003 | 07:22 PM
turboxsi's Avatar
How would i go about this?? I've never had this problem before.
Old Sep 20, 2003 | 07:24 PM
sackdz's Avatar
PIck up a tap set, toss some oil in the whole, tap it, and pickup a bolt to fit it.
Old Sep 21, 2003 | 09:48 AM
turboxsi's Avatar
Default Re: Stipped fuel rail thread!! (sackdz)
thanks for help guys anything is fixed!!!
InTheZoneAC
Apr 9, 2013 05:04 PM
Sic_DA_Nine
Mar 1, 2008 05:26 PM
type Gendy
Nov 13, 2007 05:41 PM
JDMallTHEway
Dec 15, 2004 01:18 PM
YumVTEC
Mar 25, 2003 07:18 AM
