Engine Disassembly Help
Old Sep 20, 2003 | 08:17 AM
RStoR's Avatar
Default Engine Disassembly Help
I'm beginning my first engine rebuild (definite learning process) and I'm not clear about something after reading the Helms.
Does one check Rod End Play and Crankshaft End Play <u>before</u> disassembling anything to determine abnormal wear?
Is it safe to use a number punch kit on the rod ends and crank caps to mark the cylinder number each came out of?
Should I get the entire block hot tanked before disassembly (just pan, pumps, and head removed) to clean everything up?
Any other suggestions appreciated
Old Sep 20, 2003 | 08:30 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: Engine Disassembly Help (RStoR)
yes i would definatley say check those clearences before u dissasemble that way u know what (might) need to be replaced before reasembly...(for example u wouldnt like to find out that your thrust washes are out of spec after u already bolted the caps on)..and i would not recomend hot tanking with the block assembled...as far as using a number punch ive seen people do it but i usually just clean the rods real good and just use a sharpie ....also remember to take your time...ive seen people rush just so they can brag how fast they can build a motor.not worth it...good luck
Old Sep 20, 2003 | 08:43 AM
owen_the_soyboy's Avatar
Default Re: Engine Disassembly Help (bruceleeroy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceleeroy &raquo;</TD></TR><TR><TD CLASS="quote">yes i would definatley say check those clearences before u dissasemble that way u know what (might) need to be replaced before reasembly...(for example u wouldnt like to find out that your thrust washes are out of spec after u already bolted the caps on)..and i would not recomend hot tanking with the block assembled...as far as using a number punch ive seen people do it but i usually just clean the rods real good and just use a sharpie ....also remember to take your time...ive seen people rush just so they can brag how fast they can build a motor.not worth it...good luck</TD></TR></TABLE>
I used a number punch (lightly!).
I just ordered new thrust washers along with my ACL mains and rod bearings from camp1320, they were super cheap.
hey good luck on the teardown!
Old Sep 20, 2003 | 08:45 AM
RStoR's Avatar
Check clearances first I plan to replace all the bearings too but don't want to get caught out later. Anyone else got input?
I plan to have the rods shotpeened, so I question if marker will make it thru the process. That is why I thought about a number punch.
Time is of no concern to me.
Old Sep 20, 2003 | 04:17 PM
HEAD's Avatar
if you are putting new rod and main bearings in it it doesn't make sense to me to have to check it unless you really want to, you would see abnormal wear when you see what shape the bearings are in. I would check it afterwards though.
it is safe to use a number punch
rip the motor down then get everything cleaned don't make sense to do it twice.
Old Sep 20, 2003 | 04:54 PM
SYD's Avatar
SYD
Default Re: Engine Disassembly Help (HEAD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HEAD &raquo;</TD></TR><TR><TD CLASS="quote">if you are putting new rod and main bearings in it it doesn't make sense to me to have to check it unless you really want to, you would see abnormal wear when you see what shape the bearings are in. I would check it afterwards though.
well i believe he was just talking about crank shaft endplay..not checking main and rod beaings..i think it would be better to check before so he knows if he needs to buy new ones...also checking after like u said..ive seen brand new thrust washers actually be a little too thick and have to be machined down a little..
Old Sep 28, 2003 | 05:17 PM
cmdr430's Avatar
i have an idea. sell the hatchcrap and buy another R! i'll sell you one cheap.
rak511
May 28, 2014 02:43 PM
raverx3m
13
Sep 26, 2010 02:04 PM
jdmoptiontune
33
Apr 12, 2008 07:44 AM
CONTROLLED CONFUSION
10
Nov 21, 2006 07:09 AM
youngkow
Nov 21, 2003 08:19 AM
