Problem...please give any ideas...
Old Sep 20, 2003 | 07:40 AM
Sohc Driver's Avatar
Default Problem...please give any ideas...
For the past week, i've been having wierd startups....When i start up my car....its kinda idles rough...and then smooths out.....after driving it idles smooth..etc...its only when the car has been off and i try to start the car up. Then...today..while driving to work..i noticed a loud pop on my passenger side firewall..it was freaking scary...i thought..maybe a rock or something cameup that side or something..so i didn't think much of it...but then a few seconds later...a CEL comes up..i haven't checked the code yet..im at work..but a friend is coming up to help me check it....but....when that CEL came up...I pulled over..popped the hood...i didn't see anything out of the ordinary..i checked under the car..no leaks...oil level was fine in the dip stick....this is freaking me out....any ideas?
Khoi
Old Sep 20, 2003 | 08:49 AM
Default Re: Problem...please give any ideas... (Sohc Driver)
I checked my code..its 45...anyone help me on this??
Khoi
Old Sep 20, 2003 | 09:37 AM
Andres-eh2's Avatar
Code 45
System too lean/rich
Fuel supply system, Primary O2 sensor, MAP sensor, contaminated fuel, valve clearance, exhaust leakage
Andres-eh2's Avatar
http://www.londonautoclub.org/...s.htm
Old Sep 20, 2003 | 11:39 AM
Default Re: (EGEESIX)
Well, me and a friend just got through replacing the fuel filter...and we reset the ecu..and no CEL...we also checked the primary O2 sensor..and noticed that it was stripped........but...so we think that is the problem...my question however...is....nothing explain that loud pop i heard from the passenger side firewall...to me..it sounded as if i hit a rock..and it came up and hit the car or something........any ideas?
Khoi
Old Sep 20, 2003 | 12:40 PM
Andres-eh2's Avatar
backfire? do u have an exhaust leak?
Old Sep 20, 2003 | 12:57 PM
the only leakage i could have is through that o2 sensor...but i heard it form the passenger side......firewall..it just didn't sound like a backfire......it sounded like literally...for example..get a metal spoon and knock it hard against a wood table....
Khoi
Old Sep 21, 2003 | 11:05 AM
Default Re: (Sohc Driver)
bump
JavierD16
Jul 30, 2018 02:42 PM
J.nguyen
May 20, 2006 12:37 AM
Preferio
Jul 6, 2005 08:56 AM
t . b o z
Jan 2, 2005 12:58 PM
Sohc Driver
Sep 21, 2003 06:25 PM
