weird things happening to my teg possibly a fuse or electric problem pleez help !!!!!!!!!
Old Sep 20, 2003 | 01:16 AM
fuck honda-tech's Avatar
Default weird things happening to my teg possibly a fuse or electric problem pleez help !!!!!!!!!
weird things have been happening lately. First of all A couple months ago my stereo stopped working.. I have the code and when i reset the ecu it wont let me enter a code. The fuse seems fine. About the same time my clock goes out .. cant tell time, again the fuse seems fine. Now a couple days ago I try my horn and its not working? I dont believe it .. also my alarm works but the siren wont go off..?? Can all of these things be linked to a possible short circuit .. The only thing i can think of maybe a possible malfunction when washing my motor with an open hose .. (the car is turned on while engine is being washed.)Note: when i turn my alarm on and open a door the lights flash and a ticking noise from around the steering wheel clicks till i turn it off . My hazard lights flash. Today i removed the stock stereo and there is a harness plugged into it and an antenna plug there is also another opening for another plug but im not sure if one goes in it i thought it might be where the power cord comes from does any one know how many plugs come in the back of a stock stereo . P.s I have a 99 integra gsr with out warranty sorry for the lenthy lecture but i need to get to the bottom of this please responed asap thanks
Old Sep 20, 2003 | 02:43 AM
Default Re: weird things happening to my teg possibly a fuse or electric problem pleez help !!!!!!!!! (epsom
Old Sep 20, 2003 | 05:01 AM
WOTTEG's Avatar
Electrical gremlins are no fun (but you know that).
Unfortunately this one is your fault.
Hopefuly people will learn from your example. Do NOT wash your engine bay with a hose or excessive water. Water conducts.
The "ticking" noise is a relay latching on and off, it's probably being false grounded from water in contacting a connector somewhere. Hopefully some evaporation will help you out.
Old Sep 20, 2003 | 05:08 AM
Arsenal's Avatar
Take off the negattive cable on the battery, leave it off for 5-10 mins, then reattach, watch your ears as chances are your alarm will work again, I had the same problem as you
Old Sep 20, 2003 | 03:13 PM
my stereo and clock stopped working before i ever washed my engine?
Old Sep 20, 2003 | 03:19 PM
karrar55
Oct 4, 2010 07:00 PM
Spoogen_1
May 17, 2007 09:07 AM
dflywizzrd
Acura TL, RL & ZDX
Dec 6, 2006 07:41 PM
mike93eh
Apr 28, 2005 12:59 PM
