Fuse Problem. Please help.
Old May 16, 2007 | 08:47 PM
Spoogen_1's Avatar
Default Fuse Problem. Please help.
Background Info:
In the past 3 month i had to replace the "Instrument Lights" fuse. (7.5). I dont know why but it just went out 2 times. After I replaced it the second time it stayed till present.
Now: Tonight im driving it and the fuse goes out again. I find a fuse(10) and I pop that in and nothing. I tried another 7.5 and still nothing. As I start to walk away I hit the alarm and realize that when I hit the button my lights didnt flash. Im thinking this has to be part of of the same problem.
Some of my friends say its a short somewhere, and the other say it might be a loose connection. Does anyone know what it might be, and how to fix it. If anything ill just go to my mechanic to try to track it down. thanks
Old May 17, 2007 | 07:20 AM
Spoogen_1's Avatar
Default Re: Fuse Problem. Please help. (Spoogen_1)
Anyone?
Old May 17, 2007 | 07:58 AM
sickofitall1113's Avatar
i always had a problem identifying electrical shorts. its hard to figure out exactly where its coming from. but if it keeps blowing like that theres either a problem with the thing that it powers....or a short
Old May 17, 2007 | 08:18 AM
AllMotorDan's Avatar
when did you first start blowing fuses....think about the first time you did and what you had done right before that to make it blow. check any wiring that you may have had done to the car
Old May 17, 2007 | 08:29 AM
Spoogen_1's Avatar
Default Re: (AllMotorDan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorDan &raquo;</TD></TR><TR><TD CLASS="quote">when did you first start blowing fuses....think about the first time you did and what you had done right before that to make it blow. check any wiring that you may have had done to the car </TD></TR></TABLE>
When I had the body shop fix my front end after it got hit, that night is when it was out. I put a new fuse in a it worked for about a week, then i replaced it again and it stayed on for about 3 monthes now, till last night
Old May 17, 2007 | 08:35 AM
jdm_bones's Avatar
Sounds like there might be a frayed wire somewhere back there that is making ground contact with the chasis. Remove the rear panels, and lookfor any frayed wires/ bare wires or + making - contact.
Old May 17, 2007 | 08:44 AM
^...he said the frontend. but he's right, i would check all the wiring by where they fixed the car. what else is affected when that fuse is blown?
Old May 17, 2007 | 09:01 AM
Spoogen_1's Avatar
When the fuse is out the cluster and center console lights dont light up. Also I noticed the headlights and taillights work, but dont blink when I turn the alarm on and off
Old May 17, 2007 | 09:07 AM
since you said your frontend was repaired and then it started happening then i would check your wiring for your front headlights. also if you cut into any wires in the center console or cluster check those...
98prelude98
May 17, 2010 04:22 AM
BLKDA91
Jun 19, 2008 09:02 PM
Murz
Nov 5, 2007 09:04 AM
mark2379
Sep 8, 2006 11:46 AM
