Clutch/flywheel combo
Old Sep 19, 2003 | 03:20 PM
inquisitor20's Avatar
Default Clutch/flywheel combo
When does one have to balance a clutch/flywheel combination
every time you put a new one in or only when your trying to use a flywheel not designated for your particular engine?
I'm trying to decide whether to get a combo and trying to find out whether I should have it "balanced". What exactly "balanced" means i donÂ’t know, but i read that people recommend doing that before and install.
Any thoughts?
Old Sep 19, 2003 | 09:27 PM
5thgencivic's Avatar
Default Re: Clutch/flywheel combo (inquisitor)
If the flywheel is made for the car it shouldn't have to be balanced(unless you are getting it lightened), but it should be resurfaced when replacing the clutch.
Old Sep 20, 2003 | 12:18 AM
Default Re: Clutch/flywheel combo (5thgencivic)
So if your replacing both at the same time no extra work is needed?
Old Sep 20, 2003 | 12:37 AM
TimoneX's Avatar
New User
Correct.
Old Sep 20, 2003 | 06:26 AM
spaceman's Avatar
Default Re: Clutch/flywheel combo (TimoneX)
clutchcityonline.com has some good deals..im gonna get the exedy stage1(full-faced organic)for my b16,exedy is good they are oem/performance so you know they are balanced..good luck
Old Sep 20, 2003 | 08:58 AM
bmorrisj's Avatar
Default Re: Clutch/flywheel combo (spaceman)
what about NKK clutch kits??
Old Sep 20, 2003 | 10:52 AM
spaceman's Avatar
Default Re: Clutch/flywheel combo (bmorrisj)
nkk?what is that?
Old Sep 20, 2003 | 11:03 AM
bmorrisj's Avatar
hmm, i thought it was an oem supplier, or it could just be ebay parts....
Ralleh
Honda S2000
11
Oct 13, 2009 05:40 AM
djteggy99
Sep 23, 2008 06:56 PM
mattmw88
Aug 6, 2007 10:11 AM
93sivtec
Apr 22, 2007 08:57 AM
