Integra sway bars on a 5th gen Civic?
Old Aug 22, 2001 | 08:06 PM
Jan in Omaha's Avatar
Default Integra sway bars on a 5th gen Civic?
Greetings...
Are the front sway bars interchangeable between a 3rd gen Integra and a 5th gen Civic? (I am assuming that the Integra has a larger front bar)
[Modified by Jan in Omaha, 11:07 PM 8/22/2001]
Old Aug 22, 2001 | 08:49 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Integra sway bars on a 5th gen Civic? (Jan in Omaha)
Yes, completely.
The rear ITR bar can be installed too with a BSQ or Beaks kit.
You can also use the 99-2k SI front sway (26mm), but you'll need the SI LCA's and all mounting hardware.
Old Aug 22, 2001 | 08:52 PM
Default Re: Integra sway bars on a 5th gen Civic? (B18C-EJ1)
Anyone have the specs on what bars came with what car?
Old Aug 22, 2001 | 08:55 PM
B18C-EJ1
Guest
Posts: n/a
94+ Integra Front 24mm, rear 13mm (GSR) 11mm (LS)
97+ ITR Front 24mm, Rear 22mm
92-95 Civic (EX) Front 21mm, rear 11mm (EX 4dr only)
99-2k SI Front 26mm, rear 19mm??
That's all I can remember.
Old Aug 22, 2001 | 09:00 PM
Thanks for the info!!
I have a set of Susp. Tech bars for my 92 Si but I hate how the end links hang down in the front. With a larger front bar from the Integra I can use the S.T. rear bar and not have a problem.
Time to go hit the bone yards.
Old Aug 22, 2001 | 11:08 PM
Lei Siew Long's Avatar
do sway bars make your car too stiff? and is it only better to have a sway bar in the rear as opposed to the front for more oversteer? what aftermarket company makes good sway bars?
Old Aug 22, 2001 | 11:19 PM
si00000's Avatar
New User
Did the 5th gen Si Hb have any sway bars?
Old Aug 23, 2001 | 06:14 AM
Todd00's Avatar
I said I don't want a title!
Default Re: Integra sway bars on a 5th gen Civic? (si00000)
I thought....
94-01 GSR rear sway = 14mm, LS-SE & GS = 13mm
99-00 Si rear sway = 15mm
Old Aug 23, 2001 | 06:43 AM
blaze's Avatar
nope. i gave my gs-r rear sway to my buddy with a 5g si...
Old Aug 23, 2001 | 07:22 AM
Kalokohan's Avatar
New User
Default Re: Integra sway bars on a 5th gen Civic? (blaze)
So a 3G GSR rear swaybar will fit into a 5G HB?
Old Aug 23, 2001 | 07:26 AM
Yes, but only on the front.
Old Aug 23, 2001 | 07:29 AM
g-love's Avatar
New User
does the civic ex '00 have any sway bars? i'm looking to add a front strut brace and was wondering how much of a difference it'll make
thanks
Old Aug 23, 2001 | 10:49 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Integra sway bars on a 5th gen Civic? (Todd00)
I thought....
You're probably right, I was trying to remember but I may have gotten it wrong.
Old Aug 23, 2001 | 10:50 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Integra sway bars on a 5th gen Civic? (Guardson3r3)
Yes, but you need to get the 3G Integ Rear LCA's.
Old Aug 23, 2001 | 05:34 PM
Todd00's Avatar
And I don't know how legal swapping LCAs would be for a STS class.... SP is probably a no-no too.
weekendboost
Suspension & Brakes
Jan 20, 2013 05:09 PM
VBitter
Oct 11, 2009 06:10 PM
B_CRUZ!
Jul 9, 2003 05:35 AM
93CivicSI
May 6, 2002 08:15 AM
