Integra sway bars on a 5th gen Civic?
Greetings...
Are the front sway bars interchangeable between a 3rd gen Integra and a 5th gen Civic? (I am assuming that the Integra has a larger front bar)
[Modified by Jan in Omaha, 11:07 PM 8/22/2001]
Guest
Posts: n/a
Re: Integra sway bars on a 5th gen Civic? (Jan in Omaha)
94+ Integra Front 24mm, rear 13mm (GSR) 11mm (LS)
97+ ITR Front 24mm, Rear 22mm
92-95 Civic (EX) Front 21mm, rear 11mm (EX 4dr only)
99-2k SI Front 26mm, rear 19mm??
That's all I can remember.
Re: Integra sway bars on a 5th gen Civic? (B18C-EJ1)
Thanks for the info!!
I have a set of Susp. Tech bars for my 92 Si but I hate how the end links hang down in the front. With a larger front bar from the Integra I can use the S.T. rear bar and not have a problem.
Time to go hit the bone yards.
do sway bars make your car too stiff? and is it only better to have a sway bar in the rear as opposed to the front for more oversteer? what aftermarket company makes good sway bars?
Re: Integra sway bars on a 5th gen Civic? (si00000)
Did the 5th gen Si Hb have any sway bars?
does the civic ex '00 have any sway bars? i'm looking to add a front strut brace and was wondering how much of a difference it'll make
thanks
thanks
I said I don't want a title!
So a 3G GSR rear swaybar will fit into a 5G HB?
Yes, but you need to get the 3G Integ Rear LCA's.
VBitter
10-11-2009 06:10 PM
B_CRUZ!
07-09-2003 05:35 AM
93CivicSI
05-06-2002 08:15 AM
