Timing in regards to Air/Fuel ratio
Old Sep 19, 2003 | 09:33 AM
tc's Avatar
tc
Default Timing in regards to Air/Fuel ratio
I was told bumping up timing via distributor will cause the car to run more rich.
Is this true? If so can someone explain why? I'm trying to understand.
Thanks!
Old Sep 20, 2003 | 01:00 AM
TimoneX's Avatar
New User
Default Re: Timing in regards to Air/Fuel ratio (tc)
I fail to see how advancing the timing will cause the computer to dump more fuel.
Old Sep 20, 2003 | 05:03 AM
StyleTEG's Avatar
Default Re: Timing in regards to Air/Fuel ratio (TimoneX)
The only way I could see it even remotely doing that, is if the more advanced timing cause less of the fuel to burn completely.
Old Sep 20, 2003 | 08:25 PM
TimoneX's Avatar
New User
Default Re: Timing in regards to Air/Fuel ratio (StyleTEG)
That should theoretically cause the computer to lean the mixture all else being equal.
Old Sep 21, 2003 | 06:54 PM
tc's Avatar
tc
Makes since. A local "tuner" shop told me that, and I didn't understand why. And they couldn't explain it...
Old Sep 22, 2003 | 06:10 AM
Muckman's Avatar
Moderator in Chief
Ive been told by multiple tuners ignition timing does affect AFR. I dont understand it either, would someone care to educate us ignorants?
video_voide
Engine Management and Tuning
11
Feb 22, 2013 11:48 AM
DEMNTD1
Jun 28, 2005 05:19 PM
tc
Sep 21, 2003 06:42 PM
turbotec
Mar 1, 2002 07:03 AM
