DOES IGNTION TIMING AFFECT A/F RATIO???
Old Jun 21, 2005 | 10:16 PM
DEMNTD1's Avatar
Default DOES IGNTION TIMING AFFECT A/F RATIO???
Does retarding and advancing ignition timing on the distributor affect air/fuel ratio?
Example, say ignition timing is set at 16 degrees and a/f ratio is 13.2, if I advance the timing to 18 degrees, would the air fuel get leaner or richer just by adjusting the ignition timing? And vice versa.
Running a NA setup and wanted to test different ignition timing at the track. A/F tuned to around 13.2 using wideband, but don't have it on right now and wanted to find out before hitting the track.
Old Jun 22, 2005 | 08:13 AM
TrackSpeedRacing's Avatar
Default Re: DOES IGNTION TIMING AFFECT A/F RATIO??? (DEMNTD1)
i believe that advancing your ignition timing will generally lean out your air/fuel mixture. i would just leave it where its at until you gain access to a wideband.
Old Jun 22, 2005 | 08:57 AM
JSpin's Avatar
Default Re: DOES IGNTION TIMING AFFECT A/F RATIO??? (1320JDMGSR)
ignition timing doesn't have anything to do with your a/f ratio...........think about it you have X amount of air and fuel going into your combustion chamber, if the only thing you change is IGNITION timing, you haven't changed the amount of air or fuel going in.
Old Jun 22, 2005 | 10:15 AM
Suprdave's Avatar
Default Re: DOES IGNTION TIMING AFFECT A/F RATIO??? (JSpin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpin &raquo;</TD></TR><TR><TD CLASS="quote">ignition timing doesn't have anything to do with your a/f ratio...........think about it you have X amount of air and fuel going into your combustion chamber, if the only thing you change is IGNITION timing, you haven't changed the amount of air or fuel going in.</TD></TR></TABLE>
*buzz* wrong answer...
Increasing Ignition Timing generally increases torque, which increases the fuel consumption at that load point...WHICH, will require more fuel to sustain a given AFR.
That's why when you are tuning, you tune the AFR, tune the timing...then yu have to go back and touch up the AFR Curve.
Old Jun 22, 2005 | 11:26 AM
ninesecteg's Avatar
Default Re: DOES IGNTION TIMING AFFECT A/F RATIO??? (Suprdave)
what superdave said!
Old Jun 22, 2005 | 04:04 PM
DEMNTD1's Avatar
Default Re: DOES IGNTION TIMING AFFECT A/F RATIO??? (ninesecteg)
Thank you guys for the information. I will keep it where it is until I get access to the wideband again.
Old Jun 22, 2005 | 04:57 PM
ModenaTwinTurbo's Avatar
actually both of you are right, on what you said. but who answered the question right was the first one.
ignition timing does not affect afr dirrectly, what it affects is torque not afr, the increased torque affect the afr. hahaha
no diss 2 no one just randomn nerdin
Ed-
Old Jun 22, 2005 | 06:46 PM
JSpin's Avatar
Default Re: DOES IGNTION TIMING AFFECT A/F RATIO??? (ModenaTwinTurbo)
i'll stand by my answer on this one
Old Jun 23, 2005 | 09:37 AM
Suprdave's Avatar
Ok, next time you're on the dyno jack the timing 10 degrees and watch what happens.
Old Jun 23, 2005 | 10:55 AM
JSpin's Avatar
i know what you're saying, and i agree..........but for the sake of the argument, i'll agree to disagree
Old Jun 23, 2005 | 10:17 PM
danimal's Avatar
is this what you guys are saying:
if it were possible to measure a/f ratio pre-combustion, there would be no changes when the timing is adjusted.
but since we measure at the tailpipe, the readings are subject to bsfc(brake specific fuel consumption, aka, efficiency)... as well as exhaust leaks, misfiring, etc... so is that the real a/f ratio
Old Jun 24, 2005 | 10:40 AM
JSpin's Avatar
Default Re: DOES IGNTION TIMING AFFECT A/F RATIO??? (danimal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danimal &raquo;</TD></TR><TR><TD CLASS="quote">is this what you guys are saying:
but since we measure at the tailpipe, the readings are subject to bsfc(brake specific fuel consumption, aka, efficiency)... as well as exhaust leaks, misfiring, etc... so is that the real a/f ratio </TD></TR></TABLE>
pretty much, if you could some how fire off your a/f mixture, and then rewind that same engine cycle, and simply changed the spark timing, the a/f would be the same. but for real world, superdave's got it
Old Jun 24, 2005 | 12:15 PM
danimal's Avatar
my point is that 02 sensors do not measure a/f ratio at all... they just look for oxygen.
so in theory, you had it right the first time... timing can't have an effect on a/f ratio, but as dave inferred, timing can affect the output of a motor under load.
interesting question
Old Jun 24, 2005 | 02:50 PM
dustin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpin &raquo;</TD></TR><TR><TD CLASS="quote">ignition timing doesn't have anything to do with your a/f ratio...........</TD></TR></TABLE>
Sure it does. You are changing when the burn starts. I.e., more or less time for the fuel to burn. If you advance ign timing, AFR will lean out. If you retard it, it will richen up.
Try it on the dyno. Pick a part of the powerband, and pull 5 degrees of timing without touching the fuel.... see what happens. The AFR isn't going to change a ton, but it *will* richen up.
Old Jun 24, 2005 | 07:20 PM
DEMNTD1's Avatar
Default Re: DOES IGNTION TIMING AFFECT A/F RATIO??? (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">
Try it on the dyno. Pick a part of the powerband, and pull 5 degrees of timing without touching the fuel.... see what happens. The AFR isn't going to change a ton, but it *will* richen up.</TD></TR></TABLE>
So it is safe to say on a NA vehicle where we usually run leaner at about 13.2 to 13.5 and I want to test the vehicle and advance the timing from 16 degrees to 18 degrees to increase the torque curve like mentioned previously on the post, the a/f will not get leaner by a ton so I will not get very lean and possibly damage the motor??? I am talking about advancing 2 degress of timing, all other settings staying the same.
Thanks for the info's.
Old Jun 24, 2005 | 07:44 PM
peg that distributor
who gives a ****
hahaha just kidding,
Ed-
Old Jun 25, 2005 | 08:01 AM
dustin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEMNTD1 &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks for the info's.</TD></TR></TABLE>
2 degrees of timing is not going to change the AFR enough that it would be any less "safe" than it was before.
Old Jun 26, 2005 | 09:02 PM
as_fast_as_u's Avatar
here is a off the wall q....I'm having a little bit of detonation problems....but ONLY AT 3250 RPM-3500 RPM , does not matter what gear i'm in...then it goes away. timing was advanced 2 degrees, i put it back to stock, but still a little detonation...is it safe to say the tune is a little too agressive at that point, cause like u guys are saying 2 degrees really dont affect AFR that much, right?
BTW the set up is NA, done right, and i just dont feel like answering dumb qs like what injectors i'm running, or do i have carbon built up, etc.... the set up is DONE RIGHT... the tune is in question...lol
Old Jun 28, 2005 | 05:19 PM
bump for answer
video_voide
Engine Management and Tuning
11
Feb 22, 2013 11:48 AM
Attoir
Mar 18, 2004 01:25 PM
tc
Sep 22, 2003 06:10 AM
Veil_Side_
Jan 6, 2002 12:30 AM
