Volk te37 15x7.5 ET43 - 5x114.3 + Spoon calipers?... did search
Old Sep 19, 2003 | 08:07 AM
EE8's Avatar
EE8
Default Volk te37 15x7.5 ET43 - 5x114.3 + Spoon calipers?... did search
I wonder if you guys can help me out. I know there are some extended threads covering this issue, but none adress this particular model and size. I also know that GIFF has a post with some wheels that will fit.
But I really like to get the Volks (te37 15x7.5 ET43 - 5x114.3) and need to know for sure if the above size will fit without spacers over the spoon calipers, if possible with picture.
Thanks for the info in advance.
P.S.: Don´t forget I live in Portugal and can´t test fit cause there is none around that has any of those exotic wheels.
Old Sep 19, 2003 | 08:14 AM
Ferrell's Avatar
Default Re: Volk te37 15x7.5 ET43 - 5x114.3 + Spoon calipers?... did search (EE8)
send ITRsport.com a message....
Old Sep 19, 2003 | 08:25 AM
EE8's Avatar
EE8
Default Re: Volk te37 15x7.5 ET43 - 5x114.3 + Spoon calipers?... did search (Ferrell)
I´ll try but in the mean time keep the info coming. Please
Old Sep 19, 2003 | 10:56 AM
Kengs's Avatar
Black R was using Spoon calipers with 15x7 TE37s:
Old Sep 19, 2003 | 02:12 PM
Cosworth's Avatar
Default Re: Volk te37 15x7.5 ET43 - 5x114.3 + Spoon calipers?... did search (kengs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs &raquo;</TD></TR><TR><TD CLASS="quote">Black R was using Spoon calipers with 15x7 TE37s:
But, he was running a spacer on each side.
Old Sep 19, 2003 | 02:14 PM
Kengs's Avatar
Default Re: Volk te37 15x7.5 ET43 - 5x114.3 + Spoon calipers?... did search (Cosworth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cosworth &raquo;</TD></TR><TR><TD CLASS="quote">
But, he was running a spacer on each side. </TD></TR></TABLE>
doh, my bad...im gettin old
Old Sep 19, 2003 | 02:16 PM
Chris N's Avatar
I know 15x6.5" TE-37's don't work with Spoon calipers without a spacer....
I'm not sure about 15x7. I know this has been discussed before though...
Old Sep 19, 2003 | 03:41 PM
98R-1144's Avatar
Default Re: Volk te37 15x7.5 ET43 - 5x114.3 + Spoon calipers?... did search (Chris N)
it seems to vary for the R's?? i know my 15x7 +43 te37's BARELY cleared the spoon calipers on another HT members car.. and there are some people who have to use spacers because it didn't fit on theirs.
Old Sep 19, 2003 | 03:43 PM
Chris N's Avatar
Default Re: Volk te37 15x7.5 ET43 - 5x114.3 + Spoon calipers?... did search (98R-1144)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98R-1144 &raquo;</TD></TR><TR><TD CLASS="quote">it seems to vary for the R's?? i know my 15x7 +43 te37's BARELY cleared the spoon calipers on another HT members car.. and there are some people who have to use spacers because it didn't fit on theirs.</TD></TR></TABLE>
All usdm R's have them same setup. So that can't be right.
KenE was running spacers, but that might have been for tire size issues, NOT because they didnt' fit as is. so his case above is not valid.
15x6.5" i know for sure doesn't clear. this doesn't apply either.
7" may, but no one has bothered to search, since this question is not new to this forum.
Old Sep 22, 2003 | 01:36 AM
EE8's Avatar
EE8
OK so no one is using those 7.5inch Volks with the spoon calipers!? Maybe I will have to go with some other rims. Advan or CP035 probably. Those I know will fit. Anyways thanks for the help guys.
Old Sep 22, 2003 | 07:24 AM
98R-1144's Avatar
i know it can't be right... but how can you explain it fitting for some and not others?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">
7" may, but no one has bothered to search, since this question is not new to this forum. </TD></TR></TABLE>
Old Sep 22, 2003 | 07:34 AM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98R-1144 &raquo;</TD></TR><TR><TD CLASS="quote">i know it can't be right... but how can you explain it fitting for some and not others?
Spacers.
Old Sep 22, 2003 | 01:08 PM
98R-1144's Avatar
Spacers.</TD></TR></TABLE>
er did you read what i wrote earlier? mine fit on someone else's ITR w/spoon calipers WITHOUT any spacers. and yes i know of others that do need spacers... hence my comment on something must be different even though it's the exact same car...
Todd00
Nov 15, 2007 10:07 AM
.Ryan
Oct 24, 2006 05:08 PM
JAPtheRIPPER
Dec 8, 2005 03:57 AM
volkdlr
Nov 1, 2004 10:13 PM
