Pulsing on B18C-R!!!! help!!!
Old Sep 19, 2003 | 07:14 AM
daddymax's Avatar
Default Pulsing on B18C-R!!!! help!!!
ok sometimes when I'm driving I get some pulsing.... I can feel it most at low RPM's and in 2nd.....
It only happens sometimes.. or rather sometimes worse than others. only low rpm's though. high rpms it's fine! And only happens when accelerating. If I hold an rpm it's fine. And in no gear it's fine...
It's not even that that bad, only in second it's a little rough. What could this be? Could it be my clutch? MY clutch doesn't feel as strong as it did before this problem. (I went to the track and beat on it a couple times really hard, and snapped an axle that same night)
It's a jdm type r motor in a 97 EK.....
HELP!
Old Sep 19, 2003 | 12:43 PM
daddymax's Avatar
OH YEA. and my front left shock is leaking....
Old Sep 19, 2003 | 04:34 PM
koco's Avatar
Default Re: Pulsing on B18C-R!!!! help!!! (daddymax)
Pulsing can be caused by a vacuum leak. Don't get a ticket for pulsing (hehe). A vacuum leak can be found by idling the car, watching the tach, and simultaneously spraying carb cleaner in the are of the suspected leak. The RPMs will rise when the carb cleaner is sprayed on the leak.
Old Sep 20, 2003 | 06:51 AM
daddymax's Avatar
tried that... it's not a vacuum leak. And it only hapeens when accelrating.
Old Sep 20, 2003 | 06:59 AM
turbod96ex's Avatar
Does it feel a little like a miss? Maby check the ignition system. plugs wires cap rotor ect.
Old Sep 20, 2003 | 07:35 AM
sleepyEK's Avatar
also make SURE your O2 wiring is correct, the best way is to hook a Honda PGM tester up, and since it's OBD2, you'll be able to look at the voltages for both the O2's on the data stream function. i've fixed a few like that. also, my first civic, which happened to be my first swap as well, i had wired the O2's backwards and was causing that exact same problem, exactly. so check your wiring.
Old Sep 20, 2003 | 01:11 PM
daddymax's Avatar
what's a PGM tester? Can I maybe just switch teh plugs on teh O2's?
Old Sep 20, 2003 | 01:17 PM
daddymax's Avatar
And.... did yours only do this sometimes? It seems in teh moring when I go to work it's fine.
Old Sep 20, 2003 | 01:19 PM
koco's Avatar
Default Re: (daddymax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddymax &raquo;</TD></TR><TR><TD CLASS="quote">tried that... it's not a vacuum leak. And it only hapeens when accelrating.</TD></TR></TABLE>
Mine seems to pulse a little sometimes, barely noticeable. My Ign. wires are not routed correctly, I must fix. Also I suspect my O2 sensor because I get cel sometimes.
Old Sep 20, 2003 | 06:47 PM
daddymaxx's Avatar
could my O2 sensor be "going" bad, and not bad yet?
Old Sep 20, 2003 | 07:12 PM
Sanj's Avatar
PGM-FI tester is the term Honda uses for their scan tool, its stands for Programmed Fuel Injection. This is a tool the honda dealership uses to read DTC's (diagnostic trouble codes) when ur check engine light comes on. It can also be used to retrieve valuable info on the engine management system. Don't think it will be economical for an individual to purchase one cuz i'm sure its very expensive! <U></U>
Old Sep 21, 2003 | 10:16 AM
daddymaxx's Avatar
I work at a honda dealership and I tried to hook it up, didn't work.
Old Sep 22, 2003 | 03:43 PM
Gunns's Avatar
Default Re: (daddymaxx)
This thread might help you out a bit.
https://honda-tech.com/zerothread?id=592484
Exempt
Aug 9, 2007 07:28 AM
ReGMiLLa31
Honda S2000
Oct 28, 2006 07:28 PM
_Endless_
Aug 25, 2002 08:17 AM
Johnny Blaze
Aug 18, 2002 02:02 PM
mntdewred
Jul 14, 2002 11:38 AM
