turbo h22s look here please
Old Sep 18, 2003 | 09:02 PM
machine4321's Avatar
Default turbo h22s look here please
just wondering how many miles you guys have been runnign your stock internal h22a....
also how much boost you have been running
thanks in advance
Old Sep 18, 2003 | 09:57 PM
black_sh's Avatar
Default Re: turbo h22s look here please (machine4321)
15000 miles, about 5.5 to 6 lbs
Old Sep 19, 2003 | 04:30 AM
thats not to bad ....
Old Sep 19, 2003 | 05:30 AM
fastludeh22's Avatar
Default Re: (machine4321)
~10, spiked to 12 last night...got about 150 mi.
Old Sep 19, 2003 | 05:37 AM
TurboLude97's Avatar
Default Re: (fastludeh22)
10,000 miles @ 11 psi and the only problem i have had is a broken axel
Old Sep 19, 2003 | 06:15 AM
Old_Nocturnal's Avatar
1k miles at 8-9 lbs. Still running strong
Turbolude97: Those numbers are awesome! Is that 12.9 on slicks? I am running high 13's with a 104-105 mph trap, but I just can't get out of the hole...
Sorry to highjack the post, btw
Old Sep 19, 2003 | 07:02 AM
skrewdlude's Avatar
~10000 miles, probably more. 10psi, and well tuned with hondata
0 problems.
Josh
Old Sep 19, 2003 | 01:37 PM
cool nice to see some higher boost levels....
turbolude what kind of managment you running ...
and fastlude is that 150 mi or 150 000 miles
and all all these stock set ups
Old Sep 19, 2003 | 02:50 PM
graphic's Avatar
Default Re: (TurboLude97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLude97 &raquo;</TD></TR><TR><TD CLASS="quote">10,000 miles @ 11 psi and the only problem i have had is a broken axel</TD></TR></TABLE>
yo what is your setup? i.e turbo size, fuel management and is your motor built...
Old Sep 19, 2003 | 04:25 PM
Default Re: (graphic)
it was 150, but i snapped my timing belt and ripped my cam gear off this morning.
now i need to figure out if the belt ripped off the gear, or the gear broke and snapped the belt...
btw- i was making 272@9 psi, barely tuned
Old Sep 20, 2003 | 05:08 AM
tt
Old Sep 21, 2003 | 06:15 PM
Default Re: turbo h22s look here please (Nocturnal)
yea its on 22x8" m/t slicks but the track i race at is uphill 2 degrees
the motor is stock with the exception of a low compression head gasket... the turbo is a t3/t4E 60 trim .63 a/r
engine management is just 2- 440 cc secondary's controlled by MF2 and have a/f ratio of 12:1 (ish)
Old Sep 22, 2003 | 06:33 AM
Default Re: turbo h22s look here please (TurboLude97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLude97 &raquo;</TD></TR><TR><TD CLASS="quote">yea its on 22x8" m/t slicks but the track i race at is uphill 2 degrees
engine management is just 2- 440 cc secondary's controlled by MF2 and have a/f ratio of 12:1 (ish) </TD></TR></TABLE>
Very nice... Where did you get the 22x8 MT's and what size wheel are they on? Thanks!
Old Sep 22, 2003 | 09:29 AM
if i remember correctly i got the slicks from summit
they are mounted on 15" kossi K1's
Old Sep 22, 2003 | 10:55 AM
Thanks for the information! I have wondered if a 15" wheel would clear the calipers. That should make finding a slick somewhat easier!
Keep up the good work!
mattkins91
41
May 30, 2009 01:13 PM
92integraVTECgsr
Sep 17, 2005 10:13 PM
Spooled1.6L
Feb 17, 2004 08:19 PM
DB2
Jun 18, 2003 06:17 AM
See Are X
Sep 19, 2002 01:07 PM
