replacing valve cover
Old Sep 18, 2003 | 08:24 PM
02 coupe's Avatar
Default replacing valve cover
when putting on a new valve cover, say like a jdm one or something. Do you have to buy a new gasket? also do you have to oil up the inside before putting it on? anything else?
Thanks.
Old Sep 18, 2003 | 08:48 PM
blueeg's Avatar
Default Re: replacing valve cover (02 coupe)
you should put a new gasket on but u dont need to. clean up the insides on the valve cover where the gasket sits on. i put some honda bond on the edge where it makes a half loop. been doing this for my car and customers car. never had a car come back because of a leaking valve cover.
Old Sep 19, 2003 | 05:27 AM
redlinegsr's Avatar
Default Re: replacing valve cover (blueeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueeg &raquo;</TD></TR><TR><TD CLASS="quote">you should put a new gasket on but u dont need to. clean up the insides on the valve cover where the gasket sits on. i put some honda bond on the edge where it makes a half loop. been doing this for my car and customers car. never had a car come back because of a leaking valve cover.</TD></TR></TABLE>
yea you could probably even reuse the one youe have as long as you use honda bond
Old Sep 19, 2003 | 06:00 AM
bartek_b's Avatar
Default Re: replacing valve cover (redlinegsr)
either use honda bond or just soak the gasket in Motor Oil and then put it on
Old Sep 19, 2003 | 10:06 AM
WONG FRIED RICE's Avatar
depends on how used the old gaskets are. It's fairly cheap to replace...
if i were u i'd just replace it in ADDITION to some hondabond
Old Sep 19, 2003 | 12:24 PM
Prelude Vtec 23's Avatar
Default Re: replacing valve cover (JDMB16ACRX)
If it doesnt have too many miles on it reuse, if so then replace.
Old Sep 19, 2003 | 07:41 PM
NA gs-R 05 C
Guest
Posts: n/a
it isnt a must, just clean off the old gasket and put on new honda bond (or anything thing like it).
Old Sep 19, 2003 | 10:28 PM
Stripped Honda's Avatar
99-0104
Default Re: replacing valve cover (NA gs-R 05 C)
any silcone will work you don't have to go buy that overpriced hondabond ... i get it free and i see no use in using it exclusively any grey silcone will work ... and yes dont be a cheap *** buy a new gasket because if your old gasket is hard then it will probally leak
onah
14
May 14, 2007 11:45 PM
dc5tegk20
Aug 24, 2006 12:40 AM
type Gendy
10
Sep 6, 2003 10:44 AM
GSR44
Jun 22, 2002 02:11 PM
GSR44
Jun 20, 2002 10:14 PM
