What would you do?
Old Sep 18, 2003 | 06:43 PM
matt2001teg's Avatar
Default What would you do?
If you have $4,000 to play with would you keep a stock internal motor and run a votech supercharger with after cooler or would you completly build a b20 vtec set up in a 2001 integra gsr????
Old Sep 18, 2003 | 06:49 PM
B16OnTop's Avatar
Default Re: What would you do? (matt2001teg)
i would just supercharge
Old Sep 18, 2003 | 08:05 PM
VTECorona's Avatar
Default Re: What would you do? (B16OnTop)
Turbo LS or B20
Old Sep 18, 2003 | 08:06 PM
Audi A4's Avatar
Default Re: What would you do? (VTECorona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">Turbo LS or B20</TD></TR></TABLE>
gets my vote
Old Sep 18, 2003 | 08:08 PM
fivespeedintegra's Avatar
Default Re: What would you do? (DRAG lll INTEGRA)
with 4k, i'd turbo.
Old Sep 18, 2003 | 08:55 PM
turbo craig's Avatar
deff turbo it
Old Sep 18, 2003 | 09:21 PM
2001teggsr's Avatar
Do your homework first I dont think for the money the power a vortech makes is worth it, a turbo on the other hand sounds good ....check a jackson supercharger before you buy a vortech you can run more boost with one
Old Sep 19, 2003 | 12:28 AM
TimoneX's Avatar
New User
Default Re: What would you do? (2001teggsr)
The vortech sc seems to produce the worst possible powerband. I'd look into a roots type blower(JRSC) or a small rapid spooling turbo setup like greddy's.
Old Sep 19, 2003 | 03:55 AM
EnjoyTheRideDC2's Avatar
I've installed and ran the Vortech Supercharger in a GSR. It's fun, but very painful when it comes to maintainence. If U run AC, be careful where the air filter is placed..it ruptured one of the AC lines. Also, the Aftercooler install is nasty. If you have the 2001 GSR, there is an air canister u have to relocate according to the instructions...Problem is the install was done on an earlier model and the canister is a lot smaller than the one you have. Just some things to think about. Didn't mean to rain on your parade. Turbo seems more upgradeable and easier to work on your car after install. Good luck!
Old Sep 19, 2003 | 06:51 PM
Thanks for all of your input...no votes for a built all motor setup? if anyone has a built b20 or b18 let me know some of your times/dyno numbers thanks
Old Sep 19, 2003 | 06:59 PM
itr817's Avatar
Vortech can put out good numbers but only in the top part of the powerband(i am talking the last 1k rpms)...if you want SC then go Jackson...what are your wants and plans for this car? Tell us that and we can probably give you a better answer then, Turbo or SC with out giving you reasons why it will work good with you...
Old Sep 19, 2003 | 07:37 PM
SIanara's Avatar
that turbo upgrade sounds good!
Old Sep 19, 2003 | 09:57 PM
Hites
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt2001teg &raquo;</TD></TR><TR><TD CLASS="quote">If you have $4,000 to play with would you keep a stock internal motor and run a votech supercharger with after cooler or would you completly build a b20 vtec set up in a 2001 integra gsr????</TD></TR></TABLE>
neither, but thats just me.
Old Sep 19, 2003 | 10:40 PM
infinatenexus's Avatar
4K sounds like a H22 swap to me
Old Sep 20, 2003 | 06:48 AM
Turboracer01's Avatar
TURBO
Old Sep 20, 2003 | 07:53 AM
patdemps's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt2001teg &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for all of your input...no votes for a built all motor setup? if anyone has a built b20 or b18 let me know some of your times/dyno numbers thanks
I vote all motor.
I just dynoed at 189whp..hoping for 200whp on itr cams. I have my ecu (redline, and program), cam gears, and fuel untouched so I may be able to pull it off.
my mods are: toda header, cat, 70mm exhaust, itr cams, jdm fd 4.785, flywheel, clutch, sway bars, koni yellows and neuspeed race springs, type r tranny, kaaz lsd, pully, dpr stage 6 headwork, skunk2 IM, type r aem cai, and some other goodies. thats on a b18c1. ill have my track time in a week.
Old Sep 20, 2003 | 08:02 AM
xx dc2teg xx's Avatar
Default Re: (infinatenexus)
h22 into an integra?
I would turbo it or maybe jrsc
all-motor would be good but defininetly more money to get the same performance
and vortech sucks
Old Sep 20, 2003 | 06:12 PM
I would like to have a reliable daily driven "quick" street car. I am talking mid to low 13s or better but it has to be reliable!!!!
Old Sep 20, 2003 | 06:43 PM
garados's Avatar
the greddy turbo system is good for the 98+ integras. One of my good friends had one on her 98 gsr, and it ran a 13.3 on street tires @ 6000 feet It was running great for going on 3 years, upped the boost for the last year, then she sold it for a silverado
Old Jul 6, 2004 | 09:07 AM
BoostedJeff's Avatar
Default Re: What would you do? (garados)
junk
Old Jul 6, 2004 | 09:30 AM
GsR357's Avatar
Default Re: What would you do? (JDMHatch4Me)
get turbo and change you name to matt2001TURBOteg!!!!
Old Jul 6, 2004 | 09:49 AM
GS-Rdriven's Avatar
Default Re: (itr817)
superhargers r nice but turbochargers are even nicer...so def. turbo
Old Jul 8, 2004 | 02:03 PM
slodel's Avatar
Default Re: (GS-Rdriven)
ls vtec
Old Jul 8, 2004 | 02:08 PM
RidinStock's Avatar
Default Re: (4doorhybrid)
You got enough money to do a custom turbo kit and some basic internals... I vote turbo!
nightshift
Oct 15, 2009 02:13 PM
rEnZ94tEgGy
Jul 21, 2008 01:23 PM
integracrvvtec
Sep 30, 2005 08:29 PM
ZeRo
Mar 12, 2002 01:49 PM
Matt B
Jan 27, 2002 06:51 PM
