b20 turbo
Old Jul 20, 2008 | 12:32 PM
rEnZ94tEgGy's Avatar
Default b20 turbo
would i be able to turbo my b20 completly stock with a good tune????
Old Jul 20, 2008 | 12:36 PM
vtecb18c's Avatar
Default Re: b20 turbo (rEnZ94tEgGy)
yes just keep it around 8lbs
Old Jul 20, 2008 | 07:02 PM
DiMpL3s.'s Avatar
Default Re: b20 turbo (vtecb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">yes just keep it around 8lbs </TD></TR></TABLE>
x2
Old Jul 20, 2008 | 07:25 PM
VTECth1s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rEnZ94tEgGy &raquo;</TD></TR><TR><TD CLASS="quote">would i be able to turbo my b20 completly stock with a good tune???? </TD></TR></TABLE>
Sure, you can turbo any b-series motor, with a good tune.
LOL, it depends on what turbo he's using. And pretty much what the OP's motor and turbo setup consist of.
Old Jul 20, 2008 | 08:02 PM
MatthewBoller's Avatar
TUNING IS EVERYTHING! go with a smaller turbine mostly because of this...a small turbo =better gas mileage, less boost lag, more boost on stock internals, and since the b20 is not the highest revving b-series engine so with a small turbo t3/t4 you can build full boost at around 3700rpm and redline at 7000rpm or whatever the redline maybe so the quicker you build boost the better since they have low redlines...and if you put a T88 on your b20 yes 2 lbs of boost will be sufficent but GAs mileage will go POOF* you will never build any boost till 8000rpm especially with a 4cyl and it will have an ungodly amount of boost LAG so BIGGER is not always better and remember TUNING IS everything! just my two cents!
Old Jul 20, 2008 | 08:06 PM
vtecb18c's Avatar
Default Re: (MatthewBoller)
well if your read the original post,its a bone stock b20...doesnt matter what turbo kit thats why they make boost controllers...and besides he can run on wastegate alone which with a basic turbo kit, its around 8lbs
Old Jul 21, 2008 | 01:45 AM
J. Funk's Avatar
Yes, just don't go past about 275whp
This means absolutely nothing
Old Jul 21, 2008 | 11:47 AM
vtecb18c's Avatar
Default Re: b20 turbo (J. Funk)
8lbs means nothing??? ok well let him buy a turbo kit use 10-15lbs and than you can drive by him as hes sitting on the side of the road with a softball size hole in the block
Old Jul 21, 2008 | 11:54 AM
J. Funk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">8lbs means nothing???</TD></TR></TABLE>
That is correct. Are you telling me that 8psi on a T3 will yield the same results as 8psi on a GT42? PSI means nothing.
Old Jul 21, 2008 | 12:03 PM
vtecb18c's Avatar
true but arent most basic turbo kits made to run on wastegate only if you dont have a boost controller?? i could be wrong this is a question that i would like to know
Old Jul 21, 2008 | 12:04 PM
thanh4o8's Avatar
x2
Old Jul 21, 2008 | 12:11 PM
hotrod99's Avatar
Default Re: b20 turbo (thanh4o8)
I wouldnt go past 300whp any detotation at power levels over 300hp will crack the sleeve easily especially since the sleeves on a B20 are weaker than other b-series motors...in other words find a tuner that really knows his **** or your going to be in a jam with a f***ked up motor.
Old Jul 21, 2008 | 12:20 PM
Tomdata's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Funk &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, just don't go past about 275whp</TD></TR></TABLE>
X2.
WHP is a much better way to limit power than lbs of boost. there are too many variables to predict exactly how much power a motor will make at any give boost level because all motors are different and all turbos are different.
shoot for 250-275whp and you should be fine.
Old Jul 21, 2008 | 12:36 PM
J. Funk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">true but arent most basic turbo kits made to run on wastegate only if you dont have a boost controller?? i could be wrong this is a question that i would like to know</TD></TR></TABLE>
Yes, but you can always change the wastegate spring.
Old Jul 21, 2008 | 12:39 PM
vtecb18c's Avatar
oh ok cool , well thats why i was saying 8lbs cause i figured most basic kits wouldnt exceed that
Old Jul 21, 2008 | 01:23 PM
Pat_S's Avatar
Hate how such words gets repeated numerous times and when followed, they don't know why they tend to have problems.
PSI is irrelevant, means nothing, that's all I'm going to say at this point.
holleratchaboi
Apr 30, 2008 08:54 PM
559evoboy
Apr 22, 2008 10:04 PM
g0tgot
Oct 16, 2007 03:28 PM
BlueRex1020
Sep 27, 2006 07:55 PM
B18Awon
May 6, 2006 06:44 AM
