BAR Certification: Will a B18C1 (94-01 GSR) or B17 (92-93 GSR) Intake Manifold fit onto an ITR Head
Old Sep 18, 2003 | 05:27 PM
TheREGULATOR's Avatar
Default BAR Certification: Will a B18C1 (94-up GSR) or B17 (92-93 GSR) Intake Manifold fit onto an ITR Head
Tech heads, I have a quick Question. Ok, so I take my car to the Smog Ref to see what I need to do to get it BAR Certified. Here's what they came up with as far as options.
1. Since it's a JDM ITR Motor, which is OB2, in order to get it BAR Certified as an ITR I would need to Convert my whole car to OBD2. Which is alot of work, I know.
2. I could use a GSR Intake Manifold from either a B18C1 (94-up GSR) or B17 (92-93 GSR), along with the Intake, Engine Harness, and ECU (P72 or P61) to make it BAR Certified as a OB1 1.8 GSR.
Option Number 2 is the best because my bro has a 94 GSR and I could "borrow" his stuff.
The Question is, will the GSR Intake Manifold fit onto the ITR Head? I know the GSR Head is the bastard of the B series. It takes some work to fit a GSR Head onto any other B series Block. But I do know that any B series header will work on it no problem. But of course, anytime you want an aftermarket IM, you have to specify if it's a B16/18 or GSR, so I'm confused.
If that doesn't work, will the B17 GSR IM fit onto the ITR Head? I'm tending to think so because Honda didn't Utilize the Dual Stage IM until the 94-01's. Here's another question, is there any difference between the B17's IM compared to the B16's from the Si's?
Thanx in Advance, Peace
->One Type aRg, Two Destinies<-
=[ TheREGULATOR ]= Type aRg!!!
Old Sep 18, 2003 | 06:25 PM
inspyral's Avatar
GSR and ITR IM bolt patterns are different, you can't interchange them. I believe the B17 head was also a PR3(B16, CTR, ITR), so it should fit the ITR head.
kingofbattle909
May 6, 2011 11:02 PM
SpoonCivicSir20
Sep 12, 2009 03:30 PM
LS1Bait
Jan 5, 2009 09:54 PM
hondab18civic
Feb 6, 2006 09:15 AM
hondanacura4life
Sep 5, 2002 12:02 AM
