Flow of Heads? A2 vs C5
Old Sep 18, 2003 | 04:39 PM
Rev-Olution's Avatar
Default Flow of Heads? A2 vs C5
I have noticed that some people get a c5 block, then but a b16a head on it... Is there that big of a difference in the flow of the ehad? I figured the c5 would flow better then an A2, just cause its an ITR? Do these people use the ITR IM? or just the A2? I dunno just thought it was kinda odd....
Old Sep 18, 2003 | 04:52 PM
rodrez.'s Avatar
Default Re: Flow of Heads? A2 vs C5 (Rev-Olution)
The B16 head is the same as the TypeR. The R head has a very mild p/p. I know a lot of people use B16 heads, cause they're cheaper, and easier to find than ITR heads. Some use the ITR manifold, especially if they're looking to build a poormans ITR motor.
Old Sep 18, 2003 | 05:53 PM
VTEC-DA's Avatar
Default Re: Flow of Heads? A2 vs C5 (rodrez)
A bare a2 head is the same as a bare c5 head, minus the mild p7p. The big difference is in the internals.
Old Sep 18, 2003 | 05:55 PM
cruzersi99's Avatar
Default Re: Flow of Heads? A2 vs C5 (VTEC-DA)
True.
The head of the C5 has also been hand worked in such a way that attempts to alter it usually end up with a loss of power.
The B16 head is easier to work with.
Old Sep 18, 2003 | 07:03 PM
cool, thanks for clearing it up..I heard some kids trying to tell me that it flowed a lot better....So actually there isnt that much difference beside..
1) ITR has slight P&P
2) A2 is easier to work on
Old Sep 18, 2003 | 07:05 PM
dsadas89das78934's Avatar
the c5 head does flow better than any b16 head.. due to the p/p done by honda. get the b16 head and get it worked on.. you will flow better than the c5 head and it will cost you less.
Old Sep 18, 2003 | 07:07 PM
EK MONEY's Avatar
Default Re: (soccaian)
ive heard rumors that if you purchase a C5 head brand new from the factory that it does not recieve the P&P that it does if it came in the car..
Old Sep 18, 2003 | 07:46 PM
ill phil's Avatar
Default Re: (Peagreenhatch)
The ITR head also has a different cut on the angle of the valve/seat on the intake side I believe. Leads to a little more aggressive flow.
RSant
Apr 17, 2007 05:43 PM
IT'S ME DAVID
12
Jul 1, 2005 12:13 PM
JDMlyfestyle
Jan 14, 2004 03:59 PM
nwdave
11
Jul 21, 2003 02:56 PM
BoostinDC2
Sep 18, 2001 07:03 PM
