leaking oil! please help
Old Sep 18, 2003 | 12:29 AM
BigIslandBoi's Avatar
Default leaking oil! please help
jus got the swap in and now its leaking a lot of oil...put the car on the lift and it seems to be coming from where the tranny and block meet. anybody know if any seals around there should be replaced? or any other seals i should check out?
Old Sep 18, 2003 | 03:32 AM
PainfulTeg's Avatar
Default Re: leaking oil! please help (BigIslandBoi)
rear main seal is bad.....happens alot with swaps....either faulty seal or faulty install.....it's a bitch to change, have to pull the motor away from the tranny again...i've had to do it before and I was not happy
Old Sep 18, 2003 | 11:24 AM
Default Re: leaking oil! please help (PainfulTeg)
anyone know how much it would be to fix this....parts and labor?
Old Sep 18, 2003 | 11:52 AM
pro1342's Avatar
If it's not the rear main seal, it could be the oil pan gasket. Did you change it? If so, you could have doubled up the washers that are on the studs on that side of the block....seen it happen, usually a steady drip.
Old Sep 18, 2003 | 03:47 PM
jrfinfrock's Avatar
sounds like a rear main seal to me and if you dont fix it soon you will kill the clutch too if its not already dead the seal isnt much but if you cant do it your self your looking at a couple hundred in labor probably
Old Sep 18, 2003 | 06:36 PM
koco's Avatar
If it's the rear main seal, it'll probably cost close to $200 for labor and the part itself is like $20. Make sure you find out if it's just the oil pan leaking. If someone had a turbo on the car and ghettoed it back together it's probably the oil pan.
Old Sep 19, 2003 | 12:16 AM
Default Re: leaking oil! please help (koco)
thanks!!!
hbhonda
Feb 8, 2010 12:50 PM
TXSR20DE
Feb 23, 2006 09:34 AM
EJ1 wilcox
Feb 14, 2005 10:30 PM
overdose
Apr 23, 2003 10:57 AM
CivicTuneR95
Jan 13, 2003 10:17 AM
