Ways to check to see if a o2 sensor is good??
Old Sep 17, 2003 | 07:05 PM
spencedogg's Avatar
Default Ways to check to see if a o2 sensor is good??
any ways to check to see if a o2 sensor is good/bad???
Old Sep 17, 2003 | 07:14 PM
4DRPIMPIN's Avatar
wait for your ecu to throw a code..no code. good o2..
Old Sep 18, 2003 | 02:27 AM
ginsu2k's Avatar
Default Re: Ways to check to see if a o2 sensor is good?? (spencedogg)
Yeah, you pretty much wait for it to go bad. The ECU will let you know when it's not getting the necessary voltages.
Although, you can test them with a Digital Multimeter after it warms up with engine running while measuring the output voltage. If you have a bar graph DMM it's really helpful.
But, it doesn't matter. If the engine isn't throwing a code, it doesn't really need to be replaced, unless you're **** about gas mileage.
Old Sep 18, 2003 | 03:41 AM
goodbyegti's Avatar
something like 0.3v cold 0.7 volts warm i think
Old Sep 18, 2003 | 05:59 PM
spencedogg's Avatar
well twice my motor has coded when i started the car about 2 weeks apart but i did not reset the ecu and the check engine light is gone? wtf
Old Sep 18, 2003 | 06:13 PM
Smith Wise's Avatar
Default Re: (spencedogg)
wait for it to come on, and stay on. try a different ecu if you have someone with the same set-up nearby
Old Sep 18, 2003 | 07:15 PM
mntuner2's Avatar
The only way you can really tell if its bad is with a air fuel gauge or a good voltmeter. When the voltages/readings are slow to change or not moving much then the o2 sensor is going bad. I noticed that my air fuel gauge values were slow moving and about a week later the o2 light came on. New o2 sensor, quick changes again and no code. Be carefull though, no changes may mean its in open loop (engine not hot, computer is in backup mode (many possible reasons.)) Usually if it doesn't go out of open loop you will have other engine codes.
Old Sep 18, 2003 | 10:01 PM
brianbrannon's Avatar
Default Re: Ways to check to see if a o2 sensor is good?? (mntuner2)
digital volmeter to signal wire. On warm engine floor it should hit at least .9 (rich) then when revs are coming down should hit .1 (lean) you cant check if it'snreading slow though without a lab scope
Old Sep 18, 2003 | 10:23 PM
Filliam H. Muffman's Avatar
Default Re: Ways to check to see if a o2 sensor is good?? (brianbrannon)
pee on it
Old Sep 19, 2003 | 12:44 AM
JadeDM's Avatar
if you need another working one... i got one for sale... just pm me
pedrolucas
Dec 30, 2009 06:34 PM
sakasaku
14
Oct 20, 2009 03:27 PM
mattsthru
Feb 21, 2007 01:44 AM
Koyoloeor
Oct 13, 2005 04:57 PM
EGbeater
Dec 17, 2003 07:02 PM
